Simderella opened this issue on Aug 08, 2004 ยท 5 posts
Simderella posted Sun, 08 August 2004 at 12:12 PM
I am at my whits end i'm afraid. so i thought i'd ask you clever peeps some advice... something weird has happened, i noticed it when i trie to download the freebie from awful soul.. when i click a download button things have now decided to go straight into my temporary internet folder, instead of getting the popup window asking where i would like to save it to, this is now happening on anything i try to download... and i can't think how this happened or how to fix it... So any clue/help would be great!! Sorry about this being nothing really to do with Poser, I am just really needing some help!! Thanks bunches.. -S-
DayTimer posted Sun, 08 August 2004 at 12:28 PM
Hello Sim, Awhile back another user was having the same problem. Here is the message that I posted from awhile back.... "Hey y'all, I found a solution that may work, after about an hour of trying different search terms I found the correct one. this solves the downloading to temp folder first....go to my computer.> view > folder options > file types > here look for the appropriate file type..(e.g. *zip...)WiNZIP type, select edit, at the next pop-up window, check the box..Confirm open after download...click OK...that should do it....I myself have been Wrestling with this problem for more than 6 months or so....Hope this helps..." BTW this works in WIN 98, and pretty sure it works in Win XP...for WIN XP..the path should be...MY COMPUTER>TOOLS>FOLDER OPTIONS>select the FILE TYPES tab..then scroll down to the WINZIP file type, then highlite....at the bottom of the pop-up, click on ADVANCED tab...place a check in the box near CONFIRM OPEN AFTER DOWNLOAD. Then click OK then CLOSE on the remaining popup to close out. that should do the trick... DayTimer
caulbox posted Sun, 08 August 2004 at 2:16 PM
Attached Link: http://www.tweakxp.com/tweak1602.aspx
I would have expected this to be an easy option to revert, but I've just been looking at the IE options and help all to no avail :( There's certainly a sparsity of help in Win XP. A quick search on the net suggests you're on the right lines DayTimer. Thanks for the warning in advance methinks!Simderella posted Sun, 08 August 2004 at 5:31 PM
I'm using winME.... I have no clue why is has just today started to do this.. I am very computer literate, but it has me stumpted.. thanks for your advice :)
Simderella posted Sun, 08 August 2004 at 5:36 PM
yup that fixed it!!!! thanks ;)
