TRRazor opened this issue on Aug 08, 2004 ยท 12 posts
TRRazor posted Sun, 08 August 2004 at 6:01 PM
As I saw andygraph's wonderfull marksmannship at the MP, I knew I had to buy it. But as I unpacked it and checked the content I was more than just confused.
So I checked this forum, to see if there's a tutorial, or something similiar, that would simplify the construction of the cyborg from the four different parts.
I found andygraph's tutorial but to be honest, I never was really into this whole parent-thingy. So I write those lines, with the hope, that there is somebody out there, that could describe the whole construction process, right from the start, up to the finished cyborg to me. I think I'll need an extra lesson in "parenting" Poser parts too ;).
So any help is appreciated.
Thank you very much.
Message edited on: 08/08/2004 18:03
Smoovie posted Mon, 09 August 2004 at 1:38 AM
I don't think I can explain it any better than the tutorial http://www.renderosity.com/messages.ez?Form.ShowMessage=528949
TRRazor posted Mon, 09 August 2004 at 3:19 AM
Mhhhh...if anyone could maybe explain, what he means with "give you NO Parent to this props". That would already help me a lot...
TRRazor posted Wed, 11 August 2004 at 3:07 PM
Noone here, who could help me?
andygraph posted Fri, 27 August 2004 at 12:25 PM
have you found the solution ?
TRRazor posted Tue, 31 August 2004 at 7:22 AM
No, unfortunately not :(
andygraph posted Tue, 31 August 2004 at 7:53 AM
you have all IT.A.01 items ?
TRRazor posted Fri, 03 September 2004 at 5:35 AM
yes, of course
Smaker1 posted Fri, 03 September 2004 at 6:54 AM
The methode to build a IT-A-01 complete is - choose one IT-A-01 figure (head, ...) - unparent all the prop IT-A-01 prop - load another IT-A-01 figure (leg,..) - parent the props to the new figure Warning: never move the unparented props Unparent or "give you NO Parent to this props" means: - select the prop - select "change parent" (I don't remember the menu!) - select "none" That's it! Because if you delete a figure with parented props, the props are deleted Hope it helps.
andygraph posted Fri, 03 September 2004 at 7:09 AM
many thx Smaker1 ;-)
Smaker1 posted Fri, 03 September 2004 at 8:30 AM
You're welcome Andygraph! PS: I'm waiting for your next product!
andygraph posted Fri, 03 September 2004 at 9:29 AM
