webfire opened this issue on Nov 03, 2000 ยท 6 posts
webfire posted Fri, 03 November 2000 at 5:40 AM
Hi all,I really need some advise with a Bryce question.I'm working on a very detailed model in Bryce 4.0.1.The size of the model is now at 425meg and growing.My question is are there any tricks to speed up the turn around time between adjustments?Thanxx for any ideas!
inyerface posted Fri, 03 November 2000 at 7:59 AM
switch to view as box instead of wireframe
Sinv-jica posted Fri, 03 November 2000 at 4:18 PM
another trick is to build models in sections rather then all at once and also don't do textures until the model is complete, use basic whites greys and blacks, make sure to group items together and label them so its easier to texture later
Flickerstreak posted Fri, 03 November 2000 at 5:25 PM
use the solo mode! This is an invaluable tool. A better alternative to a file that huge, however, is to make each part of the file separately, in different files. Then, at the end when you're ready to do a final version, pull them all in using either the file/merge... command or by saving the parts as object presets. --flick
webfire posted Sat, 04 November 2000 at 5:56 AM
Thanxx for your help!!! :)
Blacksteel posted Sat, 04 November 2000 at 10:30 AM
Turn the nano window to show only the background. This way the nano window does not have to update each time you reposition the camera. You won't have to wait for it to render.
