doctorkoan opened this issue on Aug 09, 2004 ยท 4 posts
doctorkoan posted Mon, 09 August 2004 at 12:14 PM
I'm trying to use this prom on the P4 Male. It seems to work great until I open Dork's mouth. The Goatee doesn't lower at all and poor dork ends up having hair in his mouth - the top of the mesh spills over past the lower lip. Does anybody have any idea how I can fix this. I'm using the toon line mode, so a chin morph and texture map won't work.
Little_Dragon posted Mon, 09 August 2004 at 4:42 PM
Well, morphing the prop is probably your best bet, unless you want to reposition the goatee slightly along its y- and z-axes, which would be somewhat unwieldy if you're doing animation. I can create an OpenLips morph for you, if you aren't that handy with magnets and the like.
doctorkoan posted Mon, 09 August 2004 at 4:52 PM
That would be very cool. I'm not much handy with any of the higher level stuff in poser. Mostly due to lack of a good modelling package that can create morph targets.
Little_Dragon posted Mon, 09 August 2004 at 5:23 PM
Already done. Only took me a few minutes, with one magnet. The morphs are designed specifically for the P4 Male; I haven't tested them with Michael. Let me check with HaiGan first, before I send you a copy.
