Tguyus opened this issue on Aug 09, 2004 ยท 3 posts
Tguyus posted Mon, 09 August 2004 at 2:18 PM
Hi folks...!
So I'm trying to create PZ2 files to affect the settings for one of Wyrmmaster's MDD deformer remotes. I can get the PZ2 pasted below to move the target parameter dial in the specific remote to the desired value, but then for some reason I get keyframes applied to every parameter for every element of the target figure. Is there anything I can change in the PZ2 file so that I set a keyframe only for the one parameter dial setting for the one prop?
Thanks! TG
[PZ2 to change the ytran setting for the PERSMagTranY parameter dial of the MDDChestPERSRemote prop, with each period = one tab right:]
version
.number 4.2
prop MDDChestPERSRemote
.channels
..valueParm PERSMagTranY
...keys
....k 0 -6
....sl 1
....spl
....sm
jupiterkris posted Fri, 13 August 2004 at 12:15 AM
Maybe you could try under main menu ... Animation>Resample Key Frames ...>CHECK Current Element Hopefully this will work
Tguyus posted Fri, 13 August 2004 at 9:34 AM
I'll try that. Thanks jupiterkris!
