Subject: Eve and Texture map -- desperatly help needed ! :-(
sanft opened this issue on Nov 04, 2000 ยท 2 posts
sanft posted Sat, 04 November 2000 at 3:49 AM
hello everybody i would need some help... my eve just won't take the texture map correctly! you know, this thing, when the map spreads all over the body but just not there where it's suposed to be! i tried to delete all the folders in connection with eve, and put her there again after restarting my computer, (thought, there might some bad things still hanging around!) but after reloading her, the same thing. i cant get the map on her body. applied it to whole body. tried so many different things. before the *.cr2 map got messed up, i also checked there, to make sure, she referres to the right geometrie file.... still no success... any help would really be appreciated! (anybody else had problems with eve and maps?) sanft
Krel posted Sat, 04 November 2000 at 6:34 AM
I would recommend you make sure you have Yarp and R~~~~?'s version of EVE......it accepts standard texture maps...you also have to apply the main texture map to the figure first, then go in and manually apply the vagina and labia map separately......it was a little tricky but I had no problem and this model is worth it....what a difference it makes for those "special" poses!!! Eve3V3....... Krel
