Mason opened this issue on Aug 16, 2004 ยท 15 posts
Mason posted Mon, 16 August 2004 at 12:26 AM
CL manager: "So, how can we make Poser 5 useless to professional people trying to produce material quickly?"
CL programmer: "Hey, I know, we'll duplicate every magnet channel on clothing attached to a figure upon loading of a scene so the user has to zero out 4 to 8 channels on each body part for each piece of clothing. And we'll duplicate them over and over and over upon each load. Plus the duplications won't have any real pattern to them so one of those smart aleck end users can't write an app or python script to go through, find the duplicate channels and remove or zero them. Imagine if they have like 4 figures in a room. Man they'll be screaming like mad."
CL manager: "Boy, that sounds good. But I assume we'll fix that after Poser 4 right?"
CL programmer: "Oh no. We won't fix it in pro pack, nor P5 revs 1 thru 3. That's the beauty of it. So now all those people trying to use high end figures without having to make MTs for all the clothes will have to constantly zero out channel after channel after channel. Plus we'll make setting the channel to 0 take like a second to 3 seconds, even on a 3 ghz P4. Or they can go through and delete all the clothes and figures and replace them in the scene. Now isn't that good?"
CL manager: "Yup, that'll make P5 almost useless to professionals who are trying to use our product for real work applications. Good thing we absolutely ignored any and all feedback from the renderosity community on the bugs that were really important to fix. Hey, this face room needs some more useless features that don't work."
Message edited on: 08/16/2004 00:28
bonnyclump posted Mon, 16 August 2004 at 1:17 AM
hysterical...
lwanmtr posted Mon, 16 August 2004 at 1:18 AM
Ha,ha..Funny. I agree, that must be an actual quoted conversation..heh. That is a big problem with magnets, and the only way I can fix it is remove the duplicated lines from the .cr2...of course, it's tedious and time consuming...magnets are great, until you have to save something for later use.
Kiera posted Mon, 16 August 2004 at 1:26 AM
Hmm, maybe I am missing something here. Why not just save your mag sets as smart props?
Mason posted Mon, 16 August 2004 at 11:02 AM
Kiera-
That's not the issue. The issue is they are already smart props. Deformer sets like Wyrmmasters are great for Vicky 3 since they will also deform clothes. They also save memory since they allow me to use any clothes on v3 without creating MTs for each clothes item.
The problem is, when you save a scene with a v3 and then reload it using a magnet pack to deform her shape and the shape of the clothes, poser will duplicate the magnet channels for the clothes item when you reload the scene. So every dial is effectivily doubled, trippled, quadrippled etc.
This makes reloading a scene a huge, time consuming situation since I either 1) have to go back through and zero all the second, third etc dials (which can be like 8 per body part on each cloth item) or I have to delete the whole figure and reload it and pose it again.
This makes batch rendering completely useless since I can't set up a scene, save it, then start a batch file to render them in full size overnight since, upon loading, poser will duplicate the magnet channels.
Magnets make v3 viable for me. If I had to make MT sets for each clothes item I'd go nuts and the memory usage would go through the roof. This has been a bug in poser since poser had magnets and, wuite frankly, I don't understand why it would even arise. It makes no logical sense and so it probably can be easily fixed. CL has had at least four chances to fix this and have not done so.
Message edited on: 08/16/2004 11:03
PJF posted Mon, 16 August 2004 at 12:50 PM
When should I expect to see this bug? I ask because I have Poser 4.0.3.126, wherein I have loaded V3 with all morphs injected, upon which I have applied the Sarah Spriteling magnet deformers. This figure wears As Shamin's Lingerie 02 set, which has its own magnet set (and has the Sarah Spriteling set applied too). When I save a scene containing the above, it reopens the same as it was saved as far as I can tell.
Photopium posted Mon, 16 August 2004 at 1:28 PM
I too have never seen this problem. Either in Poser 4 or 5. I save mag loaded characters and clothes in pz3 all the time. -WTB
Crescent posted Mon, 16 August 2004 at 3:29 PM
Something similar happens to me. If I save a figure or a scene with the SS magnets applied to clothing, then when I open up the scene again, the clothing doesn't conform properly. I have to delete the clothing, re-add them, then reapply the Conform Clothing pose. It's really annoying. P5, SR4. :(
jade_nyc posted Mon, 16 August 2004 at 4:42 PM
You're not alone Crescent - Poser 4.
caulbox posted Mon, 16 August 2004 at 5:07 PM
Another issue with dupes(?) that bugs me a bit, is when I tell Poser not to continue searching for missing textures. After what can be a very long wait, Poser inadvertently tells me once again that it couldn't find the first missing texture, and asks me again if I want to continue searching. Sometimes it only takes a brief while after that to get back to the preview window, but sometimes it seems like the entire search for missing textures cycle seems to repeat itself again? Anyone know why?
Bobbie_Boucher posted Mon, 16 August 2004 at 5:29 PM
You really should blame the artist who setup the items with incorrect texture references, rather than Poser for looking for them. Or you could fix the bad texture references with CorrectReference.
caulbox posted Mon, 16 August 2004 at 5:42 PM
Yeah maybe you're right. I've just had q quick check, and the problem seems relevant to the application of MAT pose files, rather than loading figures. Cheers!
vulcanis posted Mon, 16 August 2004 at 7:13 PM
The only time I seem to have the magnet issue is if I save a scene with multiple figures with the same magnet setup.
Farside posted Tue, 17 August 2004 at 1:38 AM
I also have the mag duplication problem all the time. Very irritating.
Riddokun posted Wed, 18 August 2004 at 11:04 PM
.bookmark
