twisted_angel_9 opened this issue on Aug 16, 2004 ยท 6 posts
twisted_angel_9 posted Mon, 16 August 2004 at 9:16 PM
When I want to save an image in PS7, I can't safe as Exact but can't, the others change the image... What can I do? Thanks.
Jumpstartme2 posted Tue, 17 August 2004 at 3:56 AM
Check your file format preferences...make sure that .gif format is checked. Then when saving, click 'save as' and on that new window that pops up, scroll thru the list of formats until you see .gif ;) Hope that helps
~Jani
Renderosity Community Admin
twisted_angel_9 posted Wed, 18 August 2004 at 2:54 PM
karosnikov posted Thu, 19 August 2004 at 12:28 AM
Exact Creates a palette using the exact colors appearing in the RGB image--an option available only if the image uses 256 or fewer colors. the reason that it's not an option is that you have designed / painted with more than 256 specific colours. an exact file / .gif can't hold anymore than that much info. I don't know why you have chosen to change the "image mode" when you can just save for web. I like those "local" ones , i'm not sure which one is the best. I have a feeling it's selective.
twisted_angel_9 posted Mon, 23 August 2004 at 11:58 AM
Have you seen the Web saving? It's like a bad 80's retro graphic. Thanks for the info.
karosnikov posted Tue, 24 August 2004 at 12:40 AM
I have & btw I think the 80's are comming back, < LMAO < .gif wouldn't be what your looking for if you wanted to sumbit a large gallery image ~ can you give us your settings. or image size / intentions?
