susanmoses opened this issue on Aug 17, 2004 ยท 18 posts
susanmoses posted Tue, 17 August 2004 at 9:47 PM
draculaz posted Tue, 17 August 2004 at 10:07 PM
yeah it could very well be the atmosphere settings. there's two ways to do this, one is through materials, the second is through postwork. afaik, rochr blends the two.
ocddougdotcom posted Tue, 17 August 2004 at 10:09 PM
Rochr often does his lights in postwork, photoshop I think. He has posted this technique in the forum here, a search on his name should bring it up.
striving posted Tue, 17 August 2004 at 10:52 PM
I believe he uses Universe Image Creator. A small program you can get a shareware version of. If I am not mistaken, he is using one of the STAR light features to make the small lights. Do a search for that program, should be easy to find.
Ornlu posted Tue, 17 August 2004 at 10:52 PM
A) ^ methinks that Whanfried has gone off the rocker. B) Rochr gets that effect in postwork as OCDDoug mentioned. THe effect can be achieved through layering the image then applying a "lighten" while color dodging/burning areas. You can also paint a noise channel and add it to lighten etc. There are many ways to do it in post work, too much to mention here. Rochr's main intense pinlight effects however are achieved in universe image editor. Not photoshop.
Ornlu posted Tue, 17 August 2004 at 10:53 PM
Woops guess we posted at the same time.
Ornlu posted Tue, 17 August 2004 at 10:58 PM
What exactly is going on here, other than some pretty immature behavior.
susanmoses posted Tue, 17 August 2004 at 11:02 PM
I have Universe Creator... just haven't used it yet... Thanks guys -Susan
tjohn posted Tue, 17 August 2004 at 11:46 PM
Is someone hearing voices? Or is someone deleting posts?
tjohn posted Tue, 17 August 2004 at 11:48 PM
And I think Rochr posted a little tut in the forum about the lights. I'd search for it but I gotta go to work. A search on Rochr's name should find it for you, Susan.
susanmoses posted Wed, 18 August 2004 at 12:00 AM
Thanks tjohn... I searched under his name and so many items came up I gave up... So I think I'll just crack open Universe Creator when I get to that point and see what happens. I'll get it somehow... -Susan
drawbridgep posted Wed, 18 August 2004 at 8:22 AM
tjohn posted Wed, 18 August 2004 at 9:38 AM
Yes, Phil, that's as I recall the gist of his tut.
susanmoses posted Wed, 18 August 2004 at 9:49 AM
Thanks Phil... seems like an interesting technique... very helpful... -Susan
Rochr posted Wed, 18 August 2004 at 10:09 AM
Attached Link: http://www.rochr.com/Citylightstransmap.jpg
Like everyone has already pointed out, those lights are done with postwork. First using the method Drawbridgep showed, and then by putting some extra flares here and there with UIC. Ive also made this transmap(just invert it), that can be used for the models. Its a little more awkvard though, since youll have to make the objects hollow, and put some lights inside. Its not as exact as postwork, but it works. :) Also want to mention, that if you use the flares in UIC, use a copy of your original image. Ive just recently noticed, that it can screw up the image quality behind/around the flares. Seems like it only happens with some textures, but still think you should know about it. :)Rudolf Herczog
Digital Artist
www.rochr.com
striving posted Wed, 18 August 2004 at 1:56 PM
See the image above.
And as best I can tell, this setting is DEFAULTED back ON every time you restart UIC.. so make sure to uncheck it each time you open it.
Message edited on: 08/18/2004 13:58
Message edited on: 08/18/2004 14:00
Rochr posted Wed, 18 August 2004 at 2:05 PM
Striving, Thats great, thanx for the tip. Thats exactly how messed up my images got. And your solution is something ild never have figured out. :) The funny thing is, that ive never experienced the problem before the last two images. Really strange.
Rudolf Herczog
Digital Artist
www.rochr.com
striving posted Wed, 18 August 2004 at 2:09 PM
Rochr, No prob. I noticed it on an image I did a while back. I knew I was saving it out of UIC as a bmp, and couldn't understand why it was getting thrashed. So I started looking around in there and that seemed to fix it. Now go back and make more killer art! ;-) -bruce
