Subject: WIP - having trouble with conforming
Cyhiraeth opened this issue on Aug 19, 2004 ยท 6 posts
Cyhiraeth posted Thu, 19 August 2004 at 4:09 PM
Used Quick Conform and the Anime Doll as the donor, but when I go to conform it, I get this weird action in the shoulder area. I've made sure my groups were all named the right way and that IK is off.
The3dZone posted Thu, 19 August 2004 at 6:38 PM
That looks like a joint parameters issue. the shirt looks like it's a loose fitting shirt so try making your inner mat spheres bigger to cover the size of the shirt and they should pop into place. The3dZone
Funny YouTube video of the week - Bu De Bu Ai
Cyhiraeth posted Thu, 19 August 2004 at 9:09 PM
How do I go about doing that?
The3dZone posted Fri, 20 August 2004 at 5:32 AM
select the offending body part and then open your joint editor(under the 'window' tab)then select bend or side to side,you'll see a green and red circle around the body part the green one is the inner mat sphere. The3dZone
Cyhiraeth posted Fri, 20 August 2004 at 9:59 AM
Thanks! That did the trick!
The3dZone posted Fri, 20 August 2004 at 12:04 PM
very welcome,glad to help :0) The3dZone
