neilp opened this issue on Aug 20, 2004 ยท 3 posts
neilp posted Fri, 20 August 2004 at 6:32 AM
I have created some eyelashes for Sara. Is there any way to parent them so they will move when Sara blinks? If the only way to do this is ERC then can anyone suggest a good tut link. Thanks NeilP
Blackhearted posted Fri, 20 August 2004 at 8:51 AM
sara has no basic eyelashes? if she did - like most poser figures do figures - you could parent them to the figure's original eyelashes (which youd set to invisible), and they would move normally. i assume in order to be parentable youd have to use the grouping tool (or uv-mapper) to set the lashes as an original group, not material. cheers, -gabriel
Jim Burton posted Fri, 20 August 2004 at 12:10 PM
No easy way to do eyelashes that I'm aware of. I'd love to do a set of false eyelashes, but the figure's I've seen blink by head morphs, not by an group. Also remember many of the morphs change the shape of the head in that area and you can start to see the dificulties.
