Subject: Really, what a silly oversight (P5 interface)
Phantast opened this issue on Aug 20, 2004 ยท 2 posts
Phantast posted Fri, 20 August 2004 at 6:16 PM
The new dial window in Poser 5 looks nice - but ... CL forgot to make it parse keystrokes properly. Adjust a dial and then try to switch camera to see the result, and URGGH the hotkeys are just ignored until you pick up the mouse and click on the wretched document window (or change camera with the mouse, which is tedious). Also, you can hit Delete to remove an item, which you THINK is selected - and find it doesn't work. Because the dial window has focus and it doesn't understand Delete. ARGGH. Click - on - the - window - and - repeat.
Little_Dragon posted Fri, 20 August 2004 at 7:13 PM
Yes, the focus issue is somewhat aggravating at times. I'd like to see a few workflow improvements in other areas of the UI. The grouping tool, for instance ... there's a button to "add by material", but not one to "remove by material". Or the magnet tool ... the "add element to deform" function only allows you to add one element at a time.
