madriver opened this issue on Aug 21, 2004 ยท 6 posts
madriver posted Sat, 21 August 2004 at 2:54 PM
Totally confused about koshini 2, which i just purchased. Bought the clothing paks 1 and 2. In Poser there is a whole category called "refits" in the character section, featuring things like gowns, boots, etc. But whenever I try to open one of these i get an error: "can't find the .obj file..." etc. I've re-installed twice, but the same thing happens. Running windows XP, Latest P4 propack update with 1 gig of ram, dual processor athlon. I just spent a lot of money on clothing paks for this character. Why are these things listed in the figures folder if there aren't any corresponding objs?? Does this mean I'll have to drop even more $$$ to buy all those other items listed under refits? And what the heck IS a refit anyway? Thanks!
disneyfabfive posted Sat, 21 August 2004 at 3:05 PM
Is this what you bought http://secure.daz3d.com/shop.php?op=itemdetails&item=1964 if it is then you need to install this and then use the refits to make them work for K2, the clothing packs are for K1 and the refits make them for for K2. The refits in the K2 files only make the K1 clothing fit on K2. If I confused you more just let me know and I will try and help some more. Beth
Crescent posted Sat, 21 August 2004 at 3:27 PM
The refit files are for people who'd bought Koshini 1 and her clothing. The files make the older K1 clothing K2 compatible. It's a curtesy for people who'd bought K1 so they don't have to buy all new versions of the outfits for K2. Cheers!
xantor posted Sat, 21 August 2004 at 4:35 PM
Daz should think about doing something like that with their new figures, they are mainly based on the unimesh so It shouldn`t be too hard for them to do.
Crescent posted Sat, 21 August 2004 at 6:44 PM
The problem is, the scaling and joint parameters are different between figures. I can jury rig M3's shirts to conform to David pretty easily with just minor tweaks for stills - the pants are a whole different matter. (That doesn't take animation into effect, either.) And it's not just a case of overall body scaling - the proportions themselves are rather different. I've run S3 clothing through the Clothing Converter so they'll fit V3 and have had to do a lot of tweaking for gaps, even after very carefully scaling everything. Cheers!
madriver posted Sat, 21 August 2004 at 7:58 PM
Hey disneyfabfive, no I didnt buy that pak, but I think I understand the whole refit thing. I only purchased K2, not K1. I needed that gown for one shot, so it's not worth buying K1 paks right now. Thanks for the info you guys.
