Forum: Photoshop
Subject: Selection "offset"
sokol opened this issue on Aug 22, 2004 ยท 5 posts
sokol posted Sun, 22 August 2004 at 7:45 PM
Hello, I'm not sure of the terminology in Photoshop, but I'm trying to do what I would call an "offset." If I make a selection, can I then take that selection and adjust it to move it out/in by a certain distance? I could have sworn that I had done this before, But i can't remember how to do it. Thanks,
lundqvist posted Mon, 23 August 2004 at 3:15 AM
Hmm. Sounds like the menu option Filter->Other->Offset ?
Char posted Mon, 23 August 2004 at 5:33 AM
Are you talking about resizing just the selection (marching ants)? If so then use the menu option SelectTransform Selection. Or SelectModifyExpand or Contract.
phenom01 posted Mon, 23 August 2004 at 9:32 AM
If you want to do an "offset" like the Autocad command then you would first need to create a copy of the selection. To move the selection, you can use either the "free transform" or if you want more precision than "numeric transform."
sokol posted Mon, 23 August 2004 at 10:00 AM
THanks guys, that helps alot!
