Subject: leg going through dress
nio103 opened this issue on Aug 23, 2004 ยท 12 posts
nio103 posted Mon, 23 August 2004 at 11:13 AM
I have learned how to make a dress:)
But now one of the legs keeps going through the skirt.
1.When its says multy group how do i fix that?
2.Do I Just delete that part that says no bone?
Manuel(Nio)
TrekkieGrrrl posted Mon, 23 August 2004 at 11:24 AM
What's the blue group? Buttock? Don't put buttocks in (or alternatively don't put thighs in, that depends a little on the model. How did you bone it? In the setup room? and is it only the right leg?
nio103 posted Mon, 23 August 2004 at 11:29 AM
first i brought the skirt of maya doll to bone. then I group it by myself on the set up room.
  1. its both sides that the leg its coming out .
  2. why not put buttocks in? or thighs Manuel(Nio) P.S ill by online for a while so ill reply as soon as i get email.
TrekkieGrrrl posted Mon, 23 August 2004 at 12:12 PM
You can't have both buttocks AND thighs as both has to be parented to the hip. And in Poser, no parent can have more than one child. So it's EITHER buttocks OR thighs (and usually thighs) but not both :o)
Jim Burton posted Mon, 23 August 2004 at 1:16 PM
I think the best E-Z way to set up a short skirt is to have it all hip mesh, with ghost thigh operators. As the figure's thighs are a child of the buttocks you will also automatically get rotations for the figures buttock's too. If you had a buttock operator you would get double rotations. Actually, a parent can have any number of children, look at the figure's hip, for example. I think you ment it the other way around, ernyoka1. ;-)
TrekkieGrrrl posted Mon, 23 August 2004 at 1:27 PM
Er.. yes, of course.. sorry for confusing the matter blush
lupus posted Mon, 23 August 2004 at 2:02 PM
Hi Manuel! I think you should try Jim Burtons advice. Otherwise (alot of mesh tweaking) you could try using only your abdomen and hip bones, adding a "skirt bone" for the rest (as a child to the hip), just for minor bending. The different poses you then control through morphs. If you still are setting up the groups in LW then just keep the Abdomen and Hip groups (as closely as possible to the original mesh) just make the remaining polys a group (part) named "skirt".
nio103 posted Mon, 23 August 2004 at 2:04 PM
can someoen explain a little about children and parent. dont understand. Parent is when you lock something to a body part right? and childern i dont know.
lupus posted Mon, 23 August 2004 at 2:52 PM
I'll try this a "simple way". Look at the image. The Hip is parent to both Abdomen and Left/Right Buttocks. This would mean that if you bend or move the "Hip bone" it's "Child bones" will follow (ie. all bones in the image). If you bend, say, the "R Buttock bone" only the "R Thigh bone" will follow. If the "R Thigh bone" had "childs" they would of course also follow.
Message edited on: 08/23/2004 14:54
nio103 posted Mon, 23 August 2004 at 4:46 PM
Thanks lupus and philc for helping me understand how to build this skirt from an obj . I learn how to comform the dress and bone the dress and group the dress. :)
Heres the a wallpaper of the dress in action
http://www.renderosity.com/viewed.ez?galleryid=747031
nio103 posted Mon, 23 August 2004 at 5:01 PM
explain what is ghost thigh operators Jim Burton and what to press to get them on the dress.
1.I never herd about ghost thigh operators.
2.thanks lupus i save the image
Manuel(Nio)
Jim Burton posted Tue, 24 August 2004 at 4:02 PM
If you take any valid, working CR2, you can have the last part (or group) in any chain as a "ghost" part, with no mesh, the mesh that would have been this part can be all in the parent of the part. I do all my shoes with ghost toes, for example. O.K., here is the E-Z way: Find a working skirt CR2 for the figure you want the dress to fit that is set up the "regular" way, with hip and buttocks in mesh, no thighs, no shins. Point it (the CR2) to your new dress mesh which is all hip part (you have to weld up any old seams, too. The CR2 calls out the OBJ file in two places as I'm sure you know. In you favorite text editor (or better yet, a CR2 editor) so a search and replace of "lButtock" with "lThigh", "rButtock" with "rThigh". Open the new CR2 in Poser, make adjustments as required. If you start from the figures CR2 it is a little harder, as you must first delete the thighs before you use that name for the buttocks. Yes, it does get complicated! You might want to look at some of the many threads at PoserPros' Characters and Clothing forum on this subject.
