Casette opened this issue on Aug 25, 2004 ยท 11 posts
Casette posted Wed, 25 August 2004 at 12:48 PM
Hi. I need an apron and a chef hat like this:
Can you help me?I need it for V2 or V3
Thanks.-
Message edited on: 08/25/2004 12:49
CASETTE
CaptainJack1 posted Wed, 25 August 2004 at 1:35 PM
Attached Link: https://home.comcast.net/~jhe1024/ChefHat.obj
I did a quick check of the usual suspects (DAZ, RDNA, TurboSquid, 3D Cafe, and Terra Incognita) and I couldn't find anything. I'm attaching a link to a chef's hat I just now whomped up in Wings 3D... I don't have a copy of Poser on this computer, so I can't check to see how it imports, but it ought to work okay, as long as the polygon smoothing doesn't warp it out of shape. I don't have the tools here to turn it into a prop file, but you should be able to import it okay. I expect a simple white texture with little or no highlighting will look okay with it.If it's close but not quite, please let me know and I'll see if I can't fix it up some more.
HTH,
Jack
Casette posted Wed, 25 August 2004 at 1:50 PM
No problem, I hope to work well with it resizing and texturing Thanks, Rafa.-
CASETTE
cooler posted Wed, 25 August 2004 at 2:08 PM
Attached Link: http://www.philc.net
PhilC has/had a chef hat & apron in his archived freebiesElsina posted Wed, 25 August 2004 at 2:44 PM
pakled posted Wed, 25 August 2004 at 10:04 PM
eh..I tried..but wrinkles didn't come out quite right..;)
Dizzie posted Thu, 26 August 2004 at 12:16 AM
CaptainJack1 posted Thu, 26 August 2004 at 6:23 AM
Yeah, it looks even worse on my machine,as shown. Just to test it, I imported the model into POV-Ray, and it seems to render okay, except for the too-well-defined edges in the band. I modeled the band at the bottom with hard edges, so the vertext normals make it look odd in POV.
I intruded the base of the hat inside, to make it hollow, and I suspect that that's part of the problem. I'd bet that Poser is getting some of those polygons to show. I'll see about modelling a different one without the interior polygons and see if that makes a difference.
Jack
CaptainJack1 posted Thu, 26 August 2004 at 7:32 PM
Attached Link: https://home.comcast.net/~jhe1024/ChefHat2.obj
Okay, this one is a little better, anyway, but it's still not great. Guess I've got a lot more to learn about modelling for Poser. :)I set the diffuse color to white and diffuse value to 1.000, specular value to 0.000, ambient color to white, and ambient value to 0.500, FWIW.
Jack
Casette posted Thu, 26 August 2004 at 10:51 PM
Thanks a lot ;)
CASETTE
CaptainJack1 posted Thu, 26 August 2004 at 10:57 PM
You're quite welcome, hope it's useful. :)
Message edited on: 08/26/2004 22:57
