Subject: need help or advise on best way to to animate a projectile
Methastopholis opened this issue on Aug 25, 2004 ยท 3 posts
Methastopholis posted Wed, 25 August 2004 at 4:38 PM
Methastopholis says: i have a projectile ??? im useing a rocket launcher & a rocket any idea on the easiest way to do this i have the ammo parented to the launcher& launcher parented to figure ok i add my bvh or pose ok when i want it to shoot out in mid animation do i change ammo parent to a camera ,the ground or what cus if i leave parented to launcher it dont shoot straight or do i just add ammo on the frame iwant it to become visble?
ockham posted Wed, 25 August 2004 at 4:54 PM
With a hand-held launcher, you should leave the projectile UNparented. Parenting the ammo to the barrel will give honest composite motion for a moving launcher, such as a gun on a tank that is moving steadily forward. In that case, the parenting will cause the tank's horizontal speed to be added to the ammo's trajectory. But for a hand-held, this addition is bad. If the soldier puts down the launcher just after firing, the path of the ammo will suddenly turn downward! Leaving the ammo unparented will also make it easier to leave it on the ground afterward.
My python page
My ShareCG freebies
texmextortilla posted Wed, 25 August 2004 at 7:05 PM
If you are using P5/PP you could get someone to write you a script, projectile motion is one of the easier things to program, I'd do it for you, but you'd have to wait an extra day or two to let me learn, Python.
