Subject: Poseable/bendable Props should be a cr2?
dke opened this issue on Nov 10, 2000 ยท 6 posts
dke posted Fri, 10 November 2000 at 12:40 PM
I've been making some bendable/poseable props, but not much luck getting them to actually BE props. I see from the free stuff that most of the poseable stuff is cr2's. Is that the preferred approach? I was thinking perhaps smart props, but all they seem to do is 'stick' somewhere. Kind of be nice to know if I'm wasting my time trying to showhorn bendable items into a pp2 file :) Bruce
JeffH posted Fri, 10 November 2000 at 1:13 PM
Yes, poseable props are actually figures in a cr2. The figure parenting is used to apply them to another figure.
steveshanks posted Fri, 10 November 2000 at 1:13 PM
It really depends on what your making as to wether you make it a prop or a figure (cr2) if say you made a robot arm and it bent past 90 degrees that would need to be a figure as a morphed prop wouldn't work.......a morph always takes the shortest route from a to b so a 95degree or higher bend will distort with the dial anywhere between 0 and 1..also if your doing a lot of movment the prop could get very big with lots of morphs so it may be best to make it a figure, i have a basic figure tutorial here http://interneteye3d.com thats suitable for a prop type of figure.......Steve
dke posted Fri, 10 November 2000 at 3:05 PM
Thanks so much. Now I can stop banging my head against getting the pp2 to recognize IK chains :) It's kind of a tail thingy, so it has a lot of pieces and 90 degree plus bends. Though I think I'll use the morphing for another part. Thanks again, Bruce
Mason posted Fri, 10 November 2000 at 3:51 PM
You can make heirarchy props with posable sub parts as props. I have a door prop that's like that with a door frame as the parent and the door as a child. Both are props. A few things char vs prop gives you is overall body control, deletion deletes the whole object, IK, poses and bending. For a door parented to a frame, its not necessary to make a char.
dke posted Sat, 11 November 2000 at 3:22 PM
That's interesting! I've put togeather multi-part props, but haven't tried setting up a parenting heirarchy. Is this sample in the fee stuff or somewhere I could glance through the pp2? Bruce
