Ethesis opened this issue on Aug 27, 2004 ยท 8 posts
Ethesis posted Fri, 27 August 2004 at 8:58 PM
Ethesis posted Fri, 27 August 2004 at 8:59 PM
Ethesis posted Fri, 27 August 2004 at 9:00 PM
I can't figure out where the yellow is coming from. Any ideas? BTW, I'm using the above graphic for both places it calls to a graphic, not just one.
Ethesis posted Sat, 28 August 2004 at 12:01 AM
http://www.renderosity.com/viewed.ez?galleryid=750369&Start=1&Artist=Ethesis&ByArtist=Yes Problem went away between renders. You can see it in the WIP version. Well, don't know how that happened, but guess I can't expect a solution if there isn't a problem anymore.
danae posted Sat, 28 August 2004 at 4:07 AM
Hi Ethesis. I can't read your setings in the image too well but the yellow tinting in the bottom of the map is very weird. It's odd that you're not getting the results with the same setting in every render and I can only assume that this is yet another P5 glitch. Have you tried tweaking the settings a bit more to see if this goes away?
Ethesis posted Sat, 28 August 2004 at 8:47 AM
danae posted Sat, 28 August 2004 at 9:11 AM
Your images looks wonderful! Hmmm, if it went away with a reboot then it almost certainly is your first P5 SR4 problem! Keep me posted if there are any more problems.
Ethesis posted Sat, 28 August 2004 at 1:51 PM
It is the hair and the KimiyA texture that make the character work. I'll let you know if anything else happens, but right now I'm happy as I can be. I'm just using the hair for this one character, so I'm hoping the problem is fixed.
