Kristta opened this issue on Aug 31, 2004 ยท 8 posts
Kristta posted Tue, 31 August 2004 at 1:02 PM
I have a character that was created by someone for the Mil Girls PT model. The character has a pronounced (ok, large) bosom. Was this done with a morph? If so, how can I put this morph into PT clothes so that this character isn't bursting from her dresses? Kristta
logansfury posted Tue, 31 August 2004 at 1:23 PM
Hi Kristta,
I just went thru this in reverse, trying to morph down the breats of a bodice for a large-breasted char down to fit a slender framed character.
You could try the utility MorphManager found here:
http://www.morphography.uk.vu/dlutility.html
this is designed to put char morphs into clothes.
If the character shape was created with magnets rather than morphs, you can apply magnets to your clothing item and expand the chest area of your garment. Magnet tut is here:
http://www.morphworld30.com/tutor.html
its about halfway down page, look for Working with Magnets 1, which is what I used, just follow the nose morph steps and replace the Additional Figures>Head Woman piece used in the tutorial with your garment, then adjust magnet positions accordingly.
One thing to note, if you follow the tutorial as is just to get practice first, and make the nose morph it teaches you, there is one typo in the instructions:
When all is said and done here are my final values for the Magnet:
zTran -0.011
yTran 0.050
xRotate -19
scale 86
should read:
yTran -0.011
zTran 0.050
xRotate -19
scale 86
note its just a simple typo where the y and z trans are swapped.
Finally, to help you with the clothing edit if you go the magnet route, here is the link to the thread with example pics where I show my edit of a bodice for a char it wasnt created for:
http://www.renderosity.com/messages.ez?Form.ShowMessage=1907402
Hope this helps :)
Logan Edited for pre-morning-coffee-typo's
Message edited on: 08/31/2004 13:26
CaptainJack1 posted Tue, 31 August 2004 at 1:27 PM
Also, if the clothing completely covers the body part, making the chest of the figure invisible might do the trick, without having to morph the chest. Jack
EnglishBob posted Tue, 31 August 2004 at 2:48 PM
If I may correct logansfury - Morph Manager does not transfer character morphs to clothes, it will only work between identical meshes. Possible solutions are: 1) Making the collars invisible, if possible, as suggested by jevans; 2) Using magnets on the clothes - easy if the figure has magnets attached, harder if not; 3) Use The Tailor (from DAZ) which does transfer figure morphs to clothing. However it involves expenditure, isn't always perfect, and works on Windows only.
logansfury posted Tue, 31 August 2004 at 5:57 PM
aw crap!! see what lack of caffine does to me? Thanks for catching that EnglishBob, I had used MorphManager and The Tailor for the same project and got em mentally scrambled :) sorry to send you the wrong direction there Kristta. Logan
EnglishBob posted Wed, 01 September 2004 at 3:07 AM
No worries LF, I see I made a bit of a boo-boo myself, now I read it back... :) If Kristta wants to use the larger chest, then making the figure's collars invisible won't work because the clothes will still have the smaller size; and if she doesn't want the larger chest, then she can just turn the morph down to 0.000, which will work for any clothing style. Unfortunately, I'm not allowed caffeine. I'm surprised I'm able to function at all, really... :/
Kristta posted Wed, 01 September 2004 at 7:17 AM
Thank you all for the suggestions and ideas. I think I'm going to get The Tailor once my credit card recovers from my latest shopping spree. Sounds like it could be useful. Again, thanks to everyone. Kristta
EnglishBob posted Wed, 01 September 2004 at 8:14 AM
The Tailor is useful, no question. I find it invaluable for adding a whole range of body morphs to clothing quickly; just don't think of it as being a magic wand, because it won't be perfect every time. It usually fails when the morph is making things smaller, then the clothes crumple and cling unnaturally. It's inevitable, given the way that The Tailor works.
