Subject: Can someone tell me the easiest way to blur pixie wings?
Methastopholis opened this issue on Sep 01, 2004 ยท 6 posts
Methastopholis posted Wed, 01 September 2004 at 5:28 PM
or point me to a tutorial on how too . im useing Poser 5
Message edited on: 09/01/2004 17:29
Message edited on: 09/01/2004 17:30
SamTherapy posted Wed, 01 September 2004 at 5:45 PM
The absolute easiest way would be to drop your image into Photoshop and play around with the image there. I suggest a render without the background, saved in PNG format (which will give you an Alpha channel which you can use to slot in the background after), and a render with the background only. After you finish getting crazy with the blur, slot the two together, and Robert is your mother's live in lover. :)
Methastopholis posted Wed, 01 September 2004 at 5:52 PM
ill give it a whirl
CaptainJack1 posted Wed, 01 September 2004 at 6:21 PM
Poser 5 can do it for you, too, although it's kinda slow. Set your pose, change your number of animation frames to oh, say, 5, go to frame 5, re-pose your wings a little further than they need to go for the blur, then in your render settings, check the "motion blur" box. You may need to experiment with the number of frames to leave the shutter open (the default, IIRC, is 0.5 frames) to get the blur you want. HTH, Jack
slinger posted Wed, 01 September 2004 at 7:15 PM
One word. TEQUILA! ~rofl~
The liver is evil - It must be punished.
semidieu posted Thu, 02 September 2004 at 2:45 PM
Attached Link: http://arcana.daz3d.com/index.php?id=785
I have done a tutorial on Poser5 Motion Blur. You could try it.
