pesuchet opened this issue on Sep 04, 2004 ยท 4 posts
pesuchet posted Sat, 04 September 2004 at 6:20 AM
I would like to export my poser figure with textures in VUE4 (I use POSER 5) I want export the fram 30 (with my dynamics cloth), but, when I save the file in .pz3, VUE4 import only the frame 1. So my question is : - can I export only the frame 30 in .pz3 file ? - how can I translate the frame 30 to frame 1 ? - is there another way for exporting figures from Poser to Vue with the textures ? Thanks for your help :)
svdl posted Sat, 04 September 2004 at 7:29 AM
Just looked at the e-on site. The Mover 5 plugin for Vue does exactly what you want.
Artalgo posted Sat, 04 September 2004 at 11:18 AM
This is what I usually do in this case: Go to frame 30 and spawn a morph target from the dyamic cloth. Delete the cloth simulation (or set Dyamic for the cloth to 0) and set the new morph to 1. Next select Edit, Memorize All. Then go to frame 1 and select Edit, Restore All. Save the file, with a new name just in case something goes wrong. It should then import into Vue properly.
pesuchet posted Sat, 04 September 2004 at 2:40 PM
ok thanks a lot for your help
