emearg opened this issue on Sep 08, 2004 ยท 12 posts
emearg posted Wed, 08 September 2004 at 12:42 AM
ynsaen posted Wed, 08 September 2004 at 1:14 AM
Ajax posted Wed, 08 September 2004 at 1:16 AM
You can probably fix your problem by clicking on the last little circle in the row of circles for the display modes. The last one is the one that makes the workspace show textures. You may have it set to "smooth shaded" at the moment, which just shows everything as an untextured model. However, there are many P5 materials that can only be seen when you render (procedural materials). There's no real reason you need to see your models with textures on them while you work on them. You can set up your scene without seeing the textures, then render when you are ready to make a picture. To save your render, go to file -> save or file -> export ->image.
View Ajax's Gallery - View
Ajax's Freestuff - View
Ajax's Store -
Send Ajax a message
TrekkieGrrrl posted Wed, 08 September 2004 at 2:32 AM
On that pic you're showing, Will IS textured. It's his default (crappy) texture. It simply IS very light. In other word, you picture shows Will, in Texture shaded mode, with his default texture. UNrendered. As long as he renders fine, you need not worry about how he looks in preview :o)
xantor posted Wed, 08 September 2004 at 3:20 AM
You don`t save an image to the library, when you render the scene go to file>-export>-image and save the screen that way. You should really read the manual, it does tell you most of the basic stuff.
emearg posted Wed, 08 September 2004 at 3:52 AM
xantor posted Wed, 08 September 2004 at 4:49 AM
That is the unrendered view of judy, the mesh goggles is the way that poser shows transparency maps on figures before they are rendered. When you render a picture and then change the view in any way the view naturally changes to the unrendered view of the scene. To make the final pictures you have to render the scene. Curious labs should have really given the poser 4 manual with poser 5 too as the poser 4 manual tells you most of the basics of poser where the poser 5 manual tends to just tell you poser 5 specific things.
TrekkieGrrrl posted Wed, 08 September 2004 at 6:04 AM
I wonder if you can still download the P4 manual as a pdf? Wort a look... I agree the P5 manual is lacking and some places directly erroneous. Still it's better than nothing :) Emearg, you should do a search for Geep's Primers here. He has made some covering the P5 basics too :o)
EnglishBob posted Wed, 08 September 2004 at 6:07 AM
If you render to the main window, as soon as you make any changes to your scene (or even if you just select something), the rendered output goes away and you revert to the preview mode.
emearg posted Wed, 08 September 2004 at 6:25 AM
I must be improving though as she had nipples on her forhead at one stage (well it's an improvement if you aren't dating her) ;-) If you are then it's probably a lost opportunity.
xantor posted Wed, 08 September 2004 at 9:25 AM
Attached Link: http://www.curiouslabs.com/filemanager/list/updates/58/65/85/?sbss=300
The poser 4 manual is available at the link. But it is a big file 32.26 megabytes.Message edited on: 09/08/2004 09:31
emearg posted Thu, 09 September 2004 at 4:26 AM
Thanks a heap Xantor.
