Subject: Can't get skins to load on Ultimate Poser Horse
Shaddex opened this issue on Sep 08, 2004 ยท 4 posts
Shaddex posted Wed, 08 September 2004 at 1:48 AM
I downloaded the Ultimate Poser Horse off of planit 3d, but I can't get textures to load on them at all. I know how to apply textures to models. But I can't get anything to work on these. Eben if I loaded the wrong texture, there was no sign or screwed up texture placeing, it just would not display what so ever. Anyone know what is up with these models?
judith posted Wed, 08 September 2004 at 2:04 AM
If you select the horse and then go to Display/Figure Style from the top menu, you'll find that it's set to "Smooth Shaded" if I remember correctly.
Select "Use Document Style" or "Texture Shaded" from the menu and it should show as you'd like.
Message edited on: 09/08/2004 02:14
What we do in life, echoes in eternity.
E-mail | Renderosity Homepage | Renderosity Store | RDNA Store
Shaddex posted Wed, 08 September 2004 at 4:33 AM
One more thing, is there away to just set it to make a whole model use all the same settings? It's annoying seting textures to a model that has a LOT of areas.. and changing the texture on each one, one by one is very annoying.. isn't there like an "add to all" option?
xantor posted Wed, 08 September 2004 at 4:57 AM
If you have poser 5: In the material room go to node options then apply to all.
