Subject: Error when opening Poser Pro?
Turtle opened this issue on Sep 15, 2004 ยท 5 posts
Turtle posted Wed, 15 September 2004 at 4:23 PM
My Poser is putting out an error when I open it up. It says, Cannot open Runtime/scripts/Lights and Cameras. I check ok and then it works like always? I have Poser Pro. Anyone know what to do and why this is doing the error??? Thank you for any help you can give me.
Love is Grandchildren.
Turtle posted Wed, 15 September 2004 at 6:52 PM
Please????
odeathoflife posted Wed, 15 September 2004 at 7:02 PM
try reinstalling, make sure to add the service releases.
♠Ω Poser eZine Ω♠
♠Ω Poser Free Stuff Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
shadownet posted Wed, 15 September 2004 at 8:38 PM
Hi Turtle, before you do a new install, try setting the prefered state again. Go to Edit>General Preference, and set the Preferred State (basically make the default window your prefered state or set up a new scene like you want it, and save that as the default). If you look in the runtime:Prefs folder you will see a pz3 file called preferredState.pz3 This is what loads on start up. My guess is the existing pz3 file that loads on start up got corrupted. Setting a new Preferred State will create a new pz3 and hopefully fix this problem. If it doesn't, than something else probably is corrupted and you will need to reinstall.
Turtle posted Wed, 15 September 2004 at 8:56 PM
I just did the restall of only the Poser Pro. and the up date service pack. Works fine now. Of course I had to remove all those dumb cartoon people. :O)) Thanks for the help. Under the scripts I was missing the camera and lights. I looked before and after.
