dark_storm opened this issue on Sep 16, 2004 ยท 20 posts
dark_storm posted Thu, 16 September 2004 at 8:05 PM
dark_storm posted Thu, 16 September 2004 at 8:06 PM
Sorry...forgot that....i'm using poser 5. :] The cassandra model is from the free place area...model from bice...
Message edited on: 09/16/2004 20:06
nickedshield posted Thu, 16 September 2004 at 8:33 PM
In order to use Cassandra you need the mil girls available at daz3d.com. What you downloaded is a figure based on that mesh.
AmbientShade posted Thu, 16 September 2004 at 8:40 PM Online Now!
when you download any model (figure, prop, etc), it normally comes in a zip file. Sometimes the creator puts it in an .exe format which installs itself to your poser library. But most of the time it comes in a .zip file. When you extract that .zip file, then open it, you will usually see more folders inside the main folder. Primarily, a folder called Runtime. In order to get a model to work properly inside poser (regardless of what version of poser you're using), the model's files need to be in the propper subfolders of your poser runtime directory. Different files have different extensions and belong in different sub-directories of poser's runtime folder. Once you have all the files for that model in the propper folders, then the model will appear in the library pallet of poser, and all you have to do to import it into your poser scene is double click it, or check the check marks at the bottom of the library pallet (which is actually the correct way). If cassandra is a completely original figure, then the character file (.cr2) for cassandra will refer poser to an object file (.obj) which is the base mesh or geometry of a figure. However, if cassandra is a figure that's based off of another figure's geometry (example, vicky 3), then cassandra's character file will require that you first have the vicky 3 model installed before cassandra can be used.
dark_storm posted Thu, 16 September 2004 at 8:53 PM
Ok...now i guess i understand a lot better. ill try this also ill take the model at daz3d. **i downloaded cassandra and cassandra fairy...both was in a .zip file and with a folder runtime. 3 folder int the runtime directory -libraries -readme -texture Thanks you very much for your help nikedshield & ExistentialDisorder :]
AmbientShade posted Thu, 16 September 2004 at 11:20 PM Online Now!
Remember, I was only using Vicky as an example. Remember to purchase the correct figure from DAZ, which would be the Mil Girl, as Nickedshield stated. 8-)
EnglishBob posted Fri, 17 September 2004 at 4:42 AM
Attached Link: http://www.morphography.uk.vu/fileguide_1.html
Here's my guide to where to put things in Poser, for future reference. A'kin had threatened to do a French translation, but I haven't heard... :)dark_storm posted Fri, 17 September 2004 at 8:24 AM
@nglishBob- Thanks you very much for your guide it's very helpful. Now i know where tu put the files correctly. :] @ExistentialDisorder- Ok ill not forgot to buy the girl from daZ. And vicky...I think you have to buy it too right?. Do you know whre i can find free nice female model to start. I want to experiment a little before starting to buy a lot of things. :] Thanks you for you help all, i realy appreciate. :]
xantor posted Fri, 17 September 2004 at 8:34 AM
Attached Link: http://www.poserforums.com/
There is a free female character called HER available at the sixus1 site You might need to be a member to download it, but membership is free. There are also some free clothes for this figure there, too.Message edited on: 09/17/2004 08:35
dark_storm posted Fri, 17 September 2004 at 8:44 AM
@xantor- Thanks you very much. Ill try something with this model. Thx for the link. I appreciate your help. :]
EnglishBob posted Fri, 17 September 2004 at 9:23 AM
Attached Link: http://www.3digitalcrafts.net/studiomaya/1download/mdb/index.html
There's also Studio Maya's Maya Doll. Free download, clothes too, on this page.xantor posted Fri, 17 September 2004 at 9:28 AM
There is one called something like lalala somewhere but I can`t remember the address. Maybe someone else can?
dark_storm posted Fri, 17 September 2004 at 10:17 AM
@EnglishBob- wow thanks you very much my friend. This maya doll lokk pretty awsome. Just downloaded it. Ill try to create something good with it. Maybe going to upload a picture soon. :] @xantor- Did lalala is a model or something? Thx for your help all. realy appreciate. :]
xantor posted Fri, 17 September 2004 at 1:08 PM
lalala is a free female figure, like you were asking about. This one has some free clothes too at the same site.
casey_42 posted Fri, 17 September 2004 at 1:16 PM
Attached Link: http://forum.daz3d.com/viewtopic.php?t=1204&start=0
Sara is also a freebie with a whole lot of support, some free and some comercial.dark_storm posted Fri, 17 September 2004 at 4:46 PM
@casey_42- Thanks you very much for the link my friend. i dwl sara. A very nice model. Thx soo much for your help. :]
xantor posted Sat, 18 September 2004 at 3:52 PM
Attached Link: http://poser-ism.vis.ne.jp/download/download.html
I found the link for lalala! The lalala figure and other downloads are at the bottom of the page and some maya doll clothes are at the top of the page.dark_storm posted Sun, 19 September 2004 at 7:45 AM
@xantor- Thanks you very much my friend for the link to lalalla. Realy appreciate. :] Another question: Vicky and Victoria...is it the same model? Thx
xantor posted Sun, 19 September 2004 at 9:28 AM
Vicky and victoria is the same model, the thing you have to watch out for is the version number victoria 1 and 2 are quite compatible with each other but victoria 3 is a completely different figure.
dark_storm posted Sun, 19 September 2004 at 4:31 PM
@xantor- Thanks you...it's a good thing to know...help a lot to solve some compatibility problem. :]
