akura_ opened this issue on Sep 18, 2004 ยท 8 posts
akura_ posted Sat, 18 September 2004 at 2:10 PM
There is no program file for tailor under programs. It say sits empty, but it still runs.
lhiannan posted Sat, 18 September 2004 at 2:57 PM
Are you saying there is no icon/shortcut in the Start-Programs menu from your toolbar? Or are you saying there is no executable file in Program Files? (!!!???) To get your shortcut into the Start-Programs bar (mine installed the Tailor shortcut on its own, try reinstalling and see if you unchecked the option)... (this is under WinXP, yours may be slightly different) Go to Start-Settings-Taskbar and Start Menu. Then click the Start Menu tab, Customize, Add, and navigate to the Tailor exe (Mine installed to Program FilesCodeTwisterThe TailorTTailor.exe
xantor posted Sat, 18 September 2004 at 5:04 PM
if you have a shortcut to the tailor right click on it and do properties and that will show you where tailor is installed but as lhiannan says it is probably installed into a drawer called codetwister.
akura_ posted Sun, 19 September 2004 at 9:49 AM
xantor posted Sun, 19 September 2004 at 12:02 PM
The installer might make an empty drawer called The tailor by accident. Try looking for a drawer called codetwister.
akura_ posted Sun, 19 September 2004 at 12:04 PM
how do I make the start menu icons smaller, cause it can't see it.
xantor posted Sun, 19 September 2004 at 12:56 PM
You cant really make them smaller, a good thing to do, is to make a drawer in the start menu for games and put all the games shortcuts into it and one for 3d programs and one for graphics programs etc that way you don
t have too many items on your start menu. I hope this helps.
akura_ posted Sun, 19 September 2004 at 8:15 PM
ok.
