Subject: Creating MATs, done tutorial - still stuck (and need sleep)
Tiny opened this issue on Sep 19, 2004 ยท 7 posts
Tiny posted Sun, 19 September 2004 at 6:36 PM
I have done following great tutorials: 'Easy Mat File Creation with Mat Pose Edit 3' and 'How to create & save a Mat file for easy to use textures!' by Mercytoo
'MAT Pose EDIT' by Stormrage
I was able to get rid of the "ghost man" and get correct image instead. :o)
But my MAT material file will not "produce" a load symbol. I only have a minus. (See image)
What do I do wrong?
Tiny
Message edited on: 09/19/2004 18:39
Thetis posted Mon, 20 September 2004 at 1:50 AM
Have you checked if the name of the MAT pose file and the image file are spelled exactly the same, and when so, if they are in the same folder?
Tiny posted Mon, 20 September 2004 at 2:23 AM
Yes, as far as I can see they are.
I have also checked in preferences that it is set for P5.
I'll try again today with another object.
Tiny
Tiny posted Mon, 20 September 2004 at 6:10 AM
Well I've been able to make it work with a character (was using a prop earlier). But the prop will still not do it.
Anyhow, I'm heading over to the MPE home page. Saw some more tuts over there. :o)
Tiny
Message edited on: 09/20/2004 06:11
TrekkieGrrrl posted Mon, 20 September 2004 at 6:26 AM
You can't use MAT poses on a prop. Only in the case where it's parented to a character. A character must be in the scene for a MAT pose to work. So that's why it won't work. You could, if you have Pro Pack or P5, take it into the Setup Room and make it a character (a character with only 1 body part, but still a character). The little plus sign will appear when something is loaded that you can use the things in the palette for, again that's why it won't appear as long as you have only a prop loaded.
Tiny posted Mon, 20 September 2004 at 6:48 AM
snip ... You could, if you have Pro Pack or P5, take it into the Setup Room and make it a character...
I just did that and now it works! :o) Thank you!
lmckenzie posted Mon, 20 September 2004 at 8:59 AM
Someone just posted a "minimal character" in freestuff.
