muralist opened this issue on Sep 20, 2004 ยท 3 posts
muralist posted Mon, 20 September 2004 at 2:13 PM
I modeled a new character based on the p4nudemalegen. I made two characters based on this figure: T HI (hi-res) and T LO (low-res). I grouped the T HI exactly like the p4 male -- down to the fingers, then copied and renamed the p4male cr2. It loads and poses fine. I did the same for the T LO figure, except I only grouped to the hands -- no fingers. When I used cr2edit to remove the fingers the hands "exploded." How do I edit the cr2 so the figure poses down tto the hands only. Also, how to remove the genital regference without losing the hip object? Thanks in advance.
nickedshield posted Mon, 20 September 2004 at 2:32 PM
Number 2: If you are using cr2 editor it's easy, search genital and the last entry turn genital to off:
EnglishBob posted Tue, 21 September 2004 at 5:15 PM
Make sure you're using version 1.51 of CR2 Editor first of all - 1.52 has bugs, and John Stallings has unfortunately disappeared. You don't actually need to remove anything from the CR2, except for neatness' sake. If Poser calls up an OBJ which has less groups than the CR2 has actors, the redundant actors will just be ignored. To be thorough, you need to remove actors from several places. - The actor section at the top - The second bigger actor section, with all the channels in it - Also remove any channels from neighbouring actors which reference the deleted actor - The addChild part of the figure section at the end - The weld part of the figure section
