Subject: 5 POINTED STAR
lazerrick opened this issue on Nov 21, 2000 ยท 4 posts
lazerrick posted Tue, 21 November 2000 at 10:59 AM
OK IM DESIGNING A 5 PONITED STAR. I DESIGNED THE STAR INSIDE INFIN D 4.5 AND EXPORTED IT INTO POSER IM TRYING TO MAKE THE STAR DANCE AS A PERSON WOULD BUT THE STAR IS UNIFORMED IN POSER HOW CAN I BREAK THE POINTS INTO INDIVIDUAL PARTS OR CAN I DOWNLOAD THE STAR MODEL FROM SOMEWHERE
JeffH posted Tue, 21 November 2000 at 11:13 AM
Attached Link: http://www.bushi3d.com
You need to learn the basics of figure creation. Try here: www.bushi3d.com
Cybermonk posted Tue, 21 November 2000 at 12:51 PM
Well I'm no poser expert for sure but.... First, when you exported was it broken in to several parts? If so, once you get it in poser you can use the grouping tool to spawn prop. This should break it up for you. If the obj was welded before theres no way to break it up in poser. But even if it is a solid piece you should be able to do some movement with magnets, on a simple model like a star. Hope this helps
____________________________________________________
"The true sign of intelligence is not knowledge but imagination".
Albert Einstein
JeffH posted Fri, 24 November 2000 at 11:28 PM
Attached Link: http://www.mitch3dseite.de/c_sstern.htm
Here's something to look at as a guide: http://www.mitch3dseite.de/c_sstern.htm It's a poseable starfish model. -JH. PS: The main site is http://www.mitch3dseite.de/
