Subject: Can someone who uses Wyrmmaster's stand-alone deformers PLEASE help me?
Terminvs_Est opened this issue on Oct 01, 2004 ยท 6 posts
Terminvs_Est posted Fri, 01 October 2004 at 2:32 AM
Hey all of you people who use Wyrmmaster's DAZ Millenium and new stand-alone deformers, please help me here! I am in URGENT need of a way to get around this annoying problem that I always get when trying to magnetize clothes to my Wyrmmaster-deformed figures. And the most annoying thing is that I've read and followed his instructions several times and I still can't get the clothing properly magnetized!:-( Please take a look here: http://uploaded.interestingnonetheless.net/TerminusEst/ttprob.JPG As I said again, I've correctly followed his instructions in the HTML files that came along with the Tammy Titans product and the clothes STILL don't correctly magnetize to the figure. And if I try to scale up and tweak the clothing using the CLOTH remotes, the person is deformed ALONG with the clothing! BTW, the clothing set is Orion1167/pretty3d's Delphi the Justifier outfit. Oh and some of you might have seen in my gallery an image of mine that used Baron Vlad Harkonnens's Princess of the Elves outfit successfully. But to be honest, it was pretty awkward and time consuming to get that contraption to fit properly to that Veronika Vixen V3 figure as yes I did have the same problems as shown in this screenshot when I first magnetized the clothing.
Lyrra posted Fri, 01 October 2004 at 3:53 AM
I've used that set many times and only had a problem once, when appying the magnets to a figure that used a v3 bodymorph. I removed the morph and the problem went away. Do your problem figures use any morphs? if they do, try dialing them down to 0 and see what happens
Kalypso posted Fri, 01 October 2004 at 4:41 AM Site Admin
The important thing to remember is to apply the LOCK to the person figure BEFORE applying clothing and magnetizing it. Did you do that? I don't have the new stand-alone sets but use the MilDeformer kit from DAZ.
Marque posted Fri, 01 October 2004 at 8:19 AM
Never had to apply the lock. I just brought in the figure, conformed the clothing and then applied the magnets. Marque
nakamuram posted Fri, 01 October 2004 at 1:21 PM
It looks like your figure has morphs as well as deformers. 1) Use Tailor to copy the body morphs to your clothes. 2) Set the morph values in the clothes to match those in your figure. 3) Apply the deformers to the clothes.
pizzone posted Fri, 01 October 2004 at 4:57 PM
I had exactly the same problem (clothes a bit "oversized") and when I was going to desperate it seemed I stumbled in the solution. When You apply the magnets (either to the figure or to the clothes) be sure to first SELECT them, without relying in what the display drop-down menu says. Even if it says that - as usually after You have loaded a cloth or figure - the cloth is selected (i.e. "thong" and body part "hip"), don't trust it (Never trust in Poser!...), but CLICK ON IT (the cloth, I mean) to be really sure that it's selected and only then conform the magnets. This way poor Tammy (and her oversized companions as well) will have clothes that fit perfectly her gorgeous shape. I hope that helps. Alberto
