Subject: Saving Pose
Inspired_Art opened this issue on Oct 07, 2004 ยท 4 posts
Inspired_Art posted Thu, 07 October 2004 at 8:49 PM
Hi, I have a hair pose that I would love to save, but when I go to save it, it shows the head only with "dots" for the hair. I see all othere poses with hair have the hair showing....any suggestions? Thank!
Eddy
sdw1952 posted Thu, 07 October 2004 at 9:08 PM
This is only a guess but going by previous threads you may have to render a png to place in the appropriate folder for the hair pose.
EnglishBob posted Fri, 08 October 2004 at 3:06 AM
Anything you save to the library will get its thumbnail from the unrendered preview in your window - in other words, things with transparency on them won't look right.
There are many workarounds :-
  1. As sdw says, render a 91 x 91 PNG and place that manually in your library. This is for Pro Pack and Poser 5 only - Poser 4 or 3 users will need to convert to RSR using P3dO Explorer.
  2. Set your preview mode to cartoon, then save.
  3. Render, and apply your render to a square. Position that in front of the camera, then making sure the hair is selected, save that.
  4. And probably others that I've forgotten. :) The PNG route is the most versatile, because you can also add text, logos etc. to your thumbnail.
Message edited on: 10/08/2004 03:07
MrDeltoid posted Fri, 08 October 2004 at 8:08 AM
With Poser 4 I use to render and then I put the rendered pic in the background. The hair turns back into dots but the rsr uses the rendered background.
