thomllama opened this issue on Oct 08, 2004 ยท 25 posts
thomllama posted Fri, 08 October 2004 at 10:03 PM
Hexagon, Carrara, Sculptris, and recently Sketchup.
thomllama posted Fri, 08 October 2004 at 10:06 PM
res1yfb1 posted Fri, 08 October 2004 at 10:13 PM
Hi....try turning color to value and keep it at 0% and in your transparency put the orange color.....I think this will do it..I do not have Carrara open to try it.....but if it does not work....I will open up carrara and find the right way. kirk saavedra www.shaders3d.com
Message edited on: 10/08/2004 22:17
res1yfb1 posted Fri, 08 October 2004 at 10:17 PM
Hi again...I just checked...The way i said was right..
kirk saavedra
www.shaders3d.com
Message edited on: 10/08/2004 22:19
FWTempest posted Fri, 08 October 2004 at 11:59 PM
In the render room.. have you made sure that 'transparency' and 'light through transparency' are checked?...
thomllama posted Sat, 09 October 2004 at 6:10 AM
thomllama posted Sat, 09 October 2004 at 6:11 AM
thomllama posted Sat, 09 October 2004 at 6:23 AM
This just all seems wrong to me...?
If i want the "color" of the item to be orange.. well then I should set "color" to orange?
If I set the Trans to a color... how do i adj "how" transparent the item is?... if trans is a "color" then how can I make it very clear? or adj it to something that is only slightly clear?
did that make sence?
Message edited on: 10/09/2004 06:24
rendererer posted Sat, 09 October 2004 at 6:41 AM
Can you attach your .car file to a message? This is a curious challenge.
falconperigot posted Sat, 09 October 2004 at 12:14 PM
FWTempest posted Sat, 09 October 2004 at 12:26 PM
you also might try increasing your ray depth... with all those rays trying to bounce around in there, maybe none are getting back out
Kixum posted Sat, 09 October 2004 at 1:44 PM
-Kix
-Kix
Kixum posted Sat, 09 October 2004 at 1:47 PM
After taking a quick look again at your first post, you do have some orange showing up in it which makes me think it's not a shadow catcher deal. If you're comfortable with it, send me the file. -Kix
-Kix
res1yfb1 posted Sat, 09 October 2004 at 1:57 PM
res1yfb1 posted Sat, 09 October 2004 at 2:04 PM
The problem is in everyones shader tree it shows the reflection way to high.....this will not look good....turn it down to 3%.....trust me the color goes into the transparency section...not the coler section...the color section gets a value...and that is where you control how much the pumkin will look transparent. thanks kirk
Kixum posted Sat, 09 October 2004 at 3:32 PM
-Kix
Kixum posted Sat, 09 October 2004 at 4:13 PM
-Kix
Kixum posted Sat, 09 October 2004 at 4:14 PM
-Kix
thomllama posted Sat, 09 October 2004 at 5:41 PM
Kixum posted Sat, 09 October 2004 at 7:01 PM
Very glad it came out! -Kix
-Kix
thomllama posted Sat, 09 October 2004 at 8:47 PM
now I have to fix it all up... :) thanks folks
Hoofdcommissaris posted Sun, 10 October 2004 at 6:37 AM
Kixum, about the 11%, I think the 'value' value of the color in the transparancy channel is above 90%, so it adds up to more then 100%. Which is forbidden by the laws of nature, if I understand correctly.
rendererer posted Sun, 10 October 2004 at 7:52 AM
Right. If 10% of your light bounces off the object, then you have only 90% left to either be absorbed by the surface, or to continue through the surface by transparency. To use an extreme example, you can't have an object that's 100% transparent and 100% reflective. That would mean that all of the light is passing through and all of the light is also bouncing off. I was never a Ray Dream user, but I played with it years ago and it handled this issue nicely - if I remember correctly, reflection and transparency were handled with a single slider control with two little arrows, one for transparency and one for reflection, Since they couldn't pass each other on the slider, it was impossible to get the percentages to overlap unrealisticallly. If you wanted more transparency you'd have to reduce the reflectivity. It was slick. I'm sure many of you are more familiar with this feature of Ray Dream. Still, in a more-strict physical model I would think that absorption of light should be handled in the same way, but as I recall it wasn't. - Joe
Kixum posted Sun, 10 October 2004 at 3:24 PM
-Kix
