LunarTick opened this issue on Oct 10, 2004 ยท 8 posts
LunarTick posted Sun, 10 October 2004 at 1:20 PM
chohole posted Sun, 10 October 2004 at 1:44 PM
If it was me I would adjust the camera on the y axis and then reposition the jet.
The greatest part of wisdom is learning to develop the ineffable genius of extracting the "neither here nor there" out of any situation...."
pogmahone posted Sun, 10 October 2004 at 1:47 PM
just my two cents' worth - and I've never done altitude renders so it's only an uneducated guess - the texture on the ground is too busy. Even if it's meant to be forest, there's too much black speckling. same for the hills. wonder what would happen if you raised the jet up much higher, but banked it, and banked or rolled the camera as well? that way you might be able to get the jet and terrain in the same frame, but with a lot of distance and atmosphere in between. the other thing I've just noticed is the height of the clouds - they look as if they're miles above the jet. how about thinning the cloud-cover, and lowering it right down to the same level of the jet, or below it.
LunarTick posted Sun, 10 October 2004 at 2:18 PM
Thanks for that information people. I'll try your ideas in the morning(3:15am here now) Pogmahone i hadn't really noticed the black speckling in the terrain texture, lucky i'm not using that one in that wip i ;) only put it in so the terrains didn't look boring while i worked on it. With the clouding i hadn't even thought about that or noticed it, i'll make those changes when i add the sky i'm using to it. Will keep you informed on how things go with it and i'll be sure to ask for any advice again ;)
Incarnadine posted Sun, 10 October 2004 at 3:08 PM
You don't normally see the afterburners so brightly during the day. I would up the transparency on them a bunch to make them less visually dominating. Try also angling the camera so it has a slight upward view, then shift your F5 so it fits your shot. You might also want to drop the terrains somewhat as well. Just some thoughts, curious to see where it goes.
Pass no temptation lightly by, for one never knows when it may pass again!
Kemal posted Sun, 10 October 2004 at 3:15 PM
I usually use Decal Colors in texture dialog for a land texture, that helps to add some depth, my 2 cents!
jedswindells posted Sun, 10 October 2004 at 6:47 PM
Ratchet up the haze and lower the clouds for starters,Then re-position your camera.Rove round with the directors' camera to find a good angle and save with memory dot.Then you can experiment and get back to base if it goes pear-shaped.
pogmahone posted Mon, 11 October 2004 at 1:42 AM
Hey, Decal is interesting! Never tried that before.....
