Forum: Bryce
Subject: Why me
LunarTick opened this issue on Oct 15, 2004 ยท 9 posts
LunarTick posted Fri, 15 October 2004 at 12:59 AM
Bryster this part is for you, i did the update for bryce less than 30 minutes ago(1:20pm Australian time) :) Now anyone else. After i did the update plus installed turbo importer, rebooted my computer which i always do after installing or updating something i have a problem with Bryce. When i went to work on a WIP Bryce did not respond, i did an ALT+CTRL+DEL and thats when i saw that bryce was not responding. I did an end task then re-opened bryce and tried to use something from my library only to fine Bryce was not responding again. I'm using Corel version bryce, i'm just wondering if the update was for that version as well or just for the DAZ version. Please one of you great people help me with this problem because the only way around it that i can see is for me to export everything from my library that i have stored in there then deleting bryce and re-installing it.
Erlik posted Fri, 15 October 2004 at 1:31 AM
Bryce is "not responding" when it's working on something. Leave it be for a while. If it's not working, try deinstalling Importer first. BTW, a better Microsoft OS is called Windows 2000 Pro.
-- erlik
Kemal posted Fri, 15 October 2004 at 1:33 AM
Hmmmm, that is very strange, I have never actually had problem with Bryce or update, i have XP and version of Bryce from Corel, dunno what DAZ importer does to it, cuz i do not have it... Update patch is still available on Corel FTP server do, here is the link ! :) CLICK ME ! :) Just hit cancel for download menager, and windows is gonna take over download process ! :) Good luck, sir ! :)
pogmahone posted Fri, 15 October 2004 at 2:04 AM
LunarTick - if it happens that you definitely have to uninstall - drag all your preset folders to somewhere like your desktop while you're uninstalling, then once you've re-installed Bryce substitute them for the 'new' preset folders. That way you'll keep your presets etc. as they are now. Uuuummmmmmm.....I think!
LunarTick posted Fri, 15 October 2004 at 2:12 AM
nope wont work that way, did it once before and still had to load everything in the libraries plus one other annoying thing is i have this silly bot called robby installed and that was an .exe file so i'll have to remove him and re-install him at a later date(much later ;) )
pogmahone posted Fri, 15 October 2004 at 2:41 AM
Probably would be better practice to have additional materials, objects etc. in separate folders that you can drag out. That doesn't work with skies, but should work with everything else. So you could view this as an opportunity to organise your libraries more logically, might make you feel better about it lol
LunarTick posted Fri, 15 October 2004 at 3:07 AM
but i'm a well organised un-organised person. i like things un-organised, you should see my computer room then you'll know what i mean :)
Zhann posted Fri, 15 October 2004 at 3:31 AM
Burn your preset libraries to CD, uninstall and just reload from the cd.
Bryce Forum Coordinator....
Quest posted Fri, 15 October 2004 at 3:42 PM
Also LunarTick, check your Windows resource memory. Windows likes to be king of the hill and often installs tasks which do nothing but suck up memory not leaving enough for other things. Removing them from your startup list might give you enough memory to start Bryce.
