Forum: Vue
Subject: Vue 5 and Poser Artist Materials Problem
Cowboyuk opened this issue on Oct 16, 2004 ยท 4 posts
Cowboyuk posted Sat, 16 October 2004 at 10:25 AM
Has anybody had any issues with importing poser 4/Artist figures into Vue 5? If I import a default figure with the default textures, it will import without any problem. However, when I try to import the same figure, with different textures they lose all there textures on import. If I open the figure in poser, all textures are correct. Is it something I'm doing wrong (probably) or has anyone else noticed this same issue.
Thanks
Cowboyuk posted Sat, 16 October 2004 at 1:01 PM
Well, after reading Wabe's reply to Spider1313's problem, I reinstalled Vue 4, and the poser model loaded with all correct textures, saved it as a *.vob and loaded it into Vue 5 that way, with all the textures still in place.
wabe posted Sun, 17 October 2004 at 10:26 AM
But if there is a difference in behaviour between V4 and V5 you should report that to E-on. To make V5 as good as V4 was. Have you ever tried to rename the Poser characters in Poser before saving them? Maybe that is another workaround.
Cowboyuk posted Sun, 17 October 2004 at 3:02 PM
I couldn't get access to the technical support - it kept timing out, so have posted a message on the eon forum. Would be interesting to find out if anyone else has seen this problem while using Poser 4 or Poser Artist, or if it's just me...
