wertu opened this issue on Oct 24, 2004 ยท 30 posts
wertu posted Sun, 24 October 2004 at 10:59 PM
wertu posted Sun, 24 October 2004 at 11:02 PM
pdxjims posted Mon, 25 October 2004 at 1:15 AM
pdxjims posted Mon, 25 October 2004 at 1:46 AM
hauksdottir posted Mon, 25 October 2004 at 3:03 AM
Jim, the first one doesn't work the way cloth works. You can try this yourself if you have a large squarish dish-drying towel (or similar) at hand. Middle of one side at the forehead, pull back, both ends falling down straight, smooth the forehead... you get deep creases on both sides above the temples. IIRC, the bottom ends are crossed and thrown over the shoulders. This provides enough tension so that it doesn't side off and an end can be pulled up over the nose quickly. In the second one, the cloth should cover the forehead more. The roll (asayib) should be horizontal. You have it the right size. It seems to tie in back, or sometimes joins with metal rings and has pendants. The veil seems to be a separate piece and there is a lot of variety. Some of these examples are masks with barely slits for eyes. I live in a mixed neighborhood (Ashram, Baptist church take all 4 corners nearby, with the Black Muslim church a couple doors down from them)... and I see all sorts of headgear. No mennonites here... but just about everybody else, I think. Everybody has a different way of tying the turbans or flipping the headscarves so that they are identifiable to each other. Anyway, I just paged through my book on Arabian costume. It is mostly traditional, identifying the tribal wear, rather than modern. A websearch on contemporary women would perhaps be more fruitful. Best if our querant posted a couple of photos or links, considering all the variety in this book! Carolly
momodot posted Mon, 25 October 2004 at 3:13 AM
hauksdottir posted Mon, 25 October 2004 at 3:46 AM
Yes! :) The white one in the middle is exactly what I was thinking of. I forgot to mention the beaded trims. The embroidery on the under dresses is elaborate and the colors very, very bright... all hidden under black.
pdxjims posted Mon, 25 October 2004 at 8:31 AM
hmmmm... give me a day... Thank you both, for the help!
movida posted Mon, 25 October 2004 at 8:51 AM
If you plan on making these available I'd love to have them also ... pretty please :)
servo posted Mon, 25 October 2004 at 10:40 AM
Add me to the list of people who like to see this kind of product available with all shown options (potential customer hint)!
momodot posted Mon, 25 October 2004 at 12:44 PM
momodot posted Mon, 25 October 2004 at 12:46 PM
momodot posted Mon, 25 October 2004 at 1:09 PM
pdxjims posted Mon, 25 October 2004 at 3:32 PM
pdxjims posted Mon, 25 October 2004 at 4:28 PM
Aureeanna posted Mon, 25 October 2004 at 6:35 PM
all I can say is....WOW!
kayjay97 posted Mon, 25 October 2004 at 8:36 PM
That looks fantastic :) The The ones you showed up further ( with the white one) look just like the ones worn here in the UAE. Wonderful work
In a world filled with causes for worry and
anxiety...
we need the peace of God standing guard over our hearts and
minds.
Jerry McCant
momodot posted Mon, 25 October 2004 at 8:52 PM
momodot posted Mon, 25 October 2004 at 10:15 PM
Message edited on: 10/25/2004 22:23
hauksdottir posted Mon, 25 October 2004 at 10:55 PM
Top of head is fine. :) Under the chin should show a crossing of fabric as momodot has in post #18... and maybe a bit wider on top of shoulders but that can be so variable (at home or in hot weather it is probably looser, if windy or dusty it is probably snugger... and some wearers are perhaps more compulsive than others about the arrangement).
SpiceBunny posted Tue, 26 October 2004 at 8:02 AM
when i look at the head skaft from #19, all i could think of was that indonesian women wear like that with the exception of the front head tip part. Those are usually a bit rounder. Anyway, it looks good.
pdxjims posted Tue, 26 October 2004 at 10:49 AM
OK. I've got the wider shoulder morphs (left and right), a face forward morph to bring it out so it's further forward on the face. Working on a lower brow morph and maybe a crossed fabric morph. The crossed fabric one won't be easy, but I'll try. I'll also ask Dodger to look at that one. He has some tools I don't have.
momodot posted Tue, 26 October 2004 at 12:28 PM
Cool.
pdxjims posted Tue, 26 October 2004 at 1:51 PM
zukeprime posted Tue, 26 October 2004 at 2:32 PM
I promise this isn't a ploy to get this for free...and don't expect anything. I'm just curious what modelling program you're using to fashion this headpiece so quickly? I'm particularly interested in the fold details, especially the ones you've created starting at the top of the head, working down the sides. I've recently purchased Amapi 7 Designer, and although I enjoy it's ease of use, I've had heaps of trouble trying to create the basis for hair. Thanks for your time!
pdxjims posted Tue, 26 October 2004 at 2:45 PM
I'm using Amapi 7, regular version. Then the P5 cloth room, then back to Amapi, then a few magnets... It's fun. The base is to start very low poly. I start with 4 splines, upper and lower ones contour to the general shape, and two VERY jagged, lightning bolt style. I then use the Goridon Surface to make a shape. You get a VERY stylized object. I combine it with other shapes I've built this way and weld them, making sure there's no holes. Then I smooth the whole thing (that's why you start with a very low poly mesh). When it smooths, you get a nice draping potential. Then, if the drape doesn't look quite natural, I'll pull it into the P5 cloth room and drape it over a figure in zero pose for a couple of frames. Export it back out, and back to Amapi for a BumpSoften and a little more fitting. If you need any more help with Amapi, IM me.
pdxjims posted Tue, 26 October 2004 at 4:29 PM
pdxjims posted Tue, 26 October 2004 at 4:39 PM
I've asked a couple of people to hold off a day or two to download, to keep my daily bandwidth down. DONE! Now I can go take my pills and take a nap!
zukeprime posted Tue, 26 October 2004 at 4:57 PM
Thanks pdxjims! A wonderful gift! I'm truly in awe of your skill in producing an incredibly nice mesh in such a short amount of time. Please, O Master, TEACH ME! lol :)
ynsaen posted Wed, 27 October 2004 at 5:19 AM
Jim, been following the thread (with nothing to contribute as I plead ignorance of the garment), and must say -- you did a great job.
let me know when it hits the store :) and if not the store, and ya need a host -- I can do that. :)
Message edited on: 10/27/2004 05:20
