tvernuccio opened this issue on Oct 27, 2004 ยท 13 posts
tvernuccio posted Wed, 27 October 2004 at 10:41 PM
Nilla posted Wed, 27 October 2004 at 11:21 PM
Sheila, When you erase the bg, use the lhaso tool and the delete key on the larger areas. When erasing along that pole you may want to take your mouse and roll out the image (making it larger) until it starts to pixelate, you get a cleaner removal this way, working larger. Hope this helps! Brenda :)
DJB posted Wed, 27 October 2004 at 11:44 PM
You can always use the magic wand tool and increase the step in it to marquee the girl and perhaps most of what she is holding.Then copy it as a new image.Flood fill the background.Then paste her back in. Remeber to have a duplicate to add any parts of her back in.If you see lines one the new selections use the eraser tool very slightly.
"The happiness of a man in this life does not consist in the
absence but in the mastery of his passions."
Wolfsnap posted Thu, 28 October 2004 at 12:36 AM
Hmmm - I've always had better luck with the pen tool - it allows you to modify the outlining after the fact, and you can do the outlining in multiple steps (not to mention it does wonders for slight curves - plot a point at the beginning, and at the end, and adjust the bezier (sp?) until you;ve got exactly what you want. Command click on the outlne and set whatever feathering ou want and PRESTO - great outline! (I'd be more than happy to help outlining this image if you want.)
SNAKEY posted Thu, 28 October 2004 at 12:37 AM
cynlee posted Thu, 28 October 2004 at 1:49 AM
well, you've already gotten some excellent suggestions, the most important on these is to work BIG!! i like using the lasso tool, freehand selection, point to point (depending on the program you're using) keep at it, we've all been here :]
tvernuccio posted Thu, 28 October 2004 at 1:44 PM
Wow!!!!! I am overwhelmed at ALL the tricks you guys have told me!!!!!!!!! THANK YOU ALL!!!!!!! I am going to print out all of your suggestions and keep them handy!!!! You guys have any idea how much this is going to help me??!! You all are the BEST!!!! Snakey...yep...so sick of that rub, rub, rub! and sick of holding my breath to still my hands!!!! arrrggggg Plus, I have arthritis in my hands...oh man...all that erasing makes my hand hurt SO bad!!! Brenda, Cindy, I am rolling it out big, but my hands just don't stop shakin. But i have some good tricks to try here!!! Yea!!!! thanks again everybody!
SNAKEY posted Thu, 28 October 2004 at 3:24 PM
You re welcome sweety.:O))
logiloglu posted Thu, 28 October 2004 at 3:59 PM
i mostly use the Path Tool to make selections.make a path around your object and after this turn it in an selection.
invert the selection and feather the selection some pixels.
now you can delete the background.
after this i used a radial softener to make the edges softer.
regards
gerhard
logiloglu posted Thu, 28 October 2004 at 4:03 PM
sorry i forgot. this work to remove a background normaly i need 15 min. - 2 hours on postwork. regards gerhard
tvernuccio posted Thu, 28 October 2004 at 6:21 PM
Oooooh...I love that feathering, Gerhard!!!! That softness makes a really nice touch!!! I will have to try this! uh...well..that is if I HAVE a radial sofener. I use PSP7. hmmm...i don't recall having this tool/filter...whatever it is. U know if there's something similar for PSP7??? Thanks SO much!!!!! sheila
logiloglu posted Thu, 28 October 2004 at 7:46 PM
Hi Sheila ! the Path tool is called Pen Tool, sorry. when you add the radial blur( there is a radial blur filter in Potoshop 7 ), make a fast selection around the parts who should be untouched( you can make a simple oval around it ). feather the selection again. you need some try to do this. have fun gerhard
logiloglu posted Thu, 28 October 2004 at 8:10 PM
oh i forgot. you can change a selection in a path too. a path is like working in Adobe Illustrator, you know what i mean ? its a Vector Tool (Bezier). its exactly what Wolfsnap said above. gerhard !!!!!!!!!!! #:O) !!!!!!!!!
