Forum: Poser Technical
Subject: free model help
TRAVISB opened this issue on Dec 04, 2000 ยท 3 posts
TRAVISB posted Mon, 04 December 2000 at 9:14 AM
i made a model in carrara and converted it to poser, but i dont know how to change the z axis to make it work in the walk desinger. the joints only seem to bend backwards help
ScottA posted Mon, 04 December 2000 at 10:33 PM
If you have Poser4 with one of the newer patches. You can try: 1.)importing the figure's .obj file as a prop. 2.)then export it as an .obj with a different name 3.)then change the two refrences in the .cr2 to point at the new file. Remember to delete the .rsr in the Geometries folder. Or the change won't take place. I confess that I've never tried making a Carrara model for Poser. So for my own knowledge. Can you tell me if this works or not? Thanks, ScottA
TRAVISB posted Tue, 05 December 2000 at 6:39 AM
i sent all of them to uv maper beforehand, ive seemed to fix one problem, but now i have to set all the joints and im clueless. maybee i will post it and see if anyone can help
