blueapples opened this issue on Oct 31, 2004 ยท 5 posts
blueapples posted Sun, 31 October 2004 at 3:02 PM
God help me. I have tried every variation of rendering I can think of but Firefly or Poser 4 will not render shadows to an animationQT file even though every option is set to cast shadows in Poser. Does anyone have a solution to this? it is totally killing me.
ynsaen posted Sun, 31 October 2004 at 3:11 PM
What are you trying to cast shadows on? If it's the default ground plane, you should add something else in place of it.
blueapples posted Sun, 31 October 2004 at 7:15 PM
okay I wasn't very clear. Sorry. here's the real issue: I want to render a QT movie with an alpha channel of a character and it's shadow(s). It seems Poser won't render the shadow unless the ground prop is visible. But I don't want the ground prop to show up in the final render, just the shadow. The only work around so far is to render the scene "current display settings" and I get the poser default shadow that is edgy and flat, not to mention doesn't follow the lighting. And I don't get the higher quality render firefly offers... A lot of people offer tutorials for creating 2d shadows in photoshop for still images from poser, but that option doesn't work for me because of the motion involved. I am trying to do 300 - 400 frames at a time with lots of motion, so I really need to be able to have the shadow poser can render, just not the ground plate.
mateo_sancarlos posted Sun, 31 October 2004 at 7:34 PM
Select ground color shader so that it renders as monochrome, with no gradients or variations. You may have a video editor that allows you to click on the ground color and mask it out or make it transparent in all frames.
blueapples posted Sun, 31 October 2004 at 8:04 PM
Found teh killer fix: http://www.runtimedna.com/messages.ez?forum_id=28&Form.ShowMessage=76990 amazingly cool!
