julien_chaplier opened this issue on Nov 02, 2004 ยท 34 posts
julien_chaplier posted Tue, 02 November 2004 at 2:05 AM
Attached Link: http://julien.chaplier.free.fr/Main.html
Hi everybody, I just added a new plug-in online : Replica. Replica duplicates objects in various configurations. The duplicatas can follow lines, squares, circles, or any kind of existing shape in the scene. Furthermore all the new instances can be sligthly different from the others in position, scaling, orientation and even shading. When the object is a light, its color can be modifed. The modification is by default a build-in noise, but it can also be based on any shader present in the scene. You can find more information on Replica on http://julien.chaplier.free.fr/Main.html . Regards, Julienres1yfb1 posted Tue, 02 November 2004 at 2:34 AM
very,very cool....i will be getting this!
TOXE posted Tue, 02 November 2004 at 3:22 AM
AaArrgh!! Really cool!! Do you think that is better that i buy a PC or wait for mac version?? I need it everyday a plugin like this!! -TOXE
julien_chaplier posted Tue, 02 November 2004 at 4:42 AM
I should have a Mac version when the public SDK for Mac is available. It should be a matter of weeks, they're working on it at Eovia. I'll have also the Mac version of Deeper and Baker around the same time. And I understand a tool like Replica was needed. Since I have it, I play a lot with it. Just a few clicks and I've got a complex scene! Julien
TOXE posted Tue, 02 November 2004 at 5:15 AM
Thanks Julien! Good news, i'll wait... -TOXE
MarkBremmer posted Tue, 02 November 2004 at 9:42 AM
Waiting is the hardest part....
memaci posted Tue, 02 November 2004 at 10:37 AM
Very cool plug-in. This is definitely one that I want to get as well. I think the logos for your plug-ins are also excellent. I will wait for the Mac version. memaci
GWeb posted Tue, 02 November 2004 at 11:52 AM
Very very cool plug ins
falconperigot posted Tue, 02 November 2004 at 12:22 PM
What great new plugin will you release next week?? ;-)
ayodejiosokoya posted Tue, 02 November 2004 at 1:21 PM
Impressive work!!!
Chrisdmd posted Tue, 02 November 2004 at 3:29 PM
Can you use this plug-in to simulate something growing along a text object...so it would look like it is appearing gradually?
Vidar posted Tue, 02 November 2004 at 4:29 PM
super cool plugin,damn,need more money for julien plugins.:)
Nicholas86 posted Tue, 02 November 2004 at 7:41 PM
julien_chaplier posted Tue, 02 November 2004 at 8:40 PM
The replicated objects use the same master object, so if this one is animated (like a vertex object with morphing), all the replicates will be too. It's so possible to make the growing effect you were talking about.
GWeb posted Tue, 02 November 2004 at 9:34 PM
Kewl!! can you make them walk??????
julien_chaplier posted Tue, 02 November 2004 at 9:43 PM
The bones too are applied on the master object, so it should be possible (I didn't try it though). But they will all follow the same animation cycle, and they don't have the same orientation, so I guess some will walk underground and other toward the sky.
GWeb posted Tue, 02 November 2004 at 9:52 PM
This Replica is really a good tool!! About the animation stuff is other thing but I am sure you will get around to it in next version of Replica!! Your creativeness is great investment!! Thank you for making Carrara more value than it originally offered.
Vidar posted Wed, 03 November 2004 at 12:24 AM
very very cool,lets make a carrara version of lord of the rings.:)
Hoofdcommissaris posted Wed, 03 November 2004 at 6:30 AM
Wow Julien! Keep 'em coming! I have to wait for the Mac version. But ArchiTools is fun enough in the meantime. (And C4 is not arrived either)
PAGZone posted Wed, 03 November 2004 at 8:03 PM
Excellent. I love to read about more plug-ins and this one looks superb. Ditto on the Mac version. Paul
bwtr posted Thu, 04 November 2004 at 8:44 PM
Trying to repeat the Tree on terrain tutorial on C3 the computer jambs at each try though very carefull to copy. First note is that the grayscale shader I made reproduces as white on the peaks!
bwtr
julien_chaplier posted Fri, 05 November 2004 at 12:28 AM
Here's something I forgot to do: the tutorial was made with a beta version. In the release, the build-in noise has a greater amplitude than before, so to reproduce the tutorial, the scaling values should be lower to about half of the displayed values. I'll update the screenshot later. For the grayscale shader, you can use a Carrara environment shader, or a vertical gradient. The one I used is in the Veloute plug-in.
bwtr posted Fri, 05 November 2004 at 7:13 PM
Thanks Julien but you have raised a huge list of questions. These may be best answered if you could show screen shots of EACH of the three grayscale alternative and of the two numerical settings thingumies of the app for the trees. Having problems with the Replica trees being elevated above the landscape. This (will!) be the best Carrara add on ever I think.
bwtr
julien_chaplier posted Fri, 05 November 2004 at 8:39 PM
The scaling is relative to the hotpoint, so it's really important to place it at the base of the tree. But if this is done, the trees shouldn't be elevated over the ground. They can look elevated in the real time rendering because the terrain use a lighter version of its mesh to be displayed, but the final rendering should be fine. Can you send me your file before the replication is done and the parameters you used if you still have a problem, I'll look at it. And I'll update the tutorial this week end and put the scene and the shader available for download.
julien_chaplier posted Sat, 06 November 2004 at 2:23 AM
The tutorial is updated, let me know if the shaders work fine
bwtr posted Sat, 06 November 2004 at 5:27 PM
WOW! Are you on call as a plumber as well? Why can't the rest of the world be as efficient. I am going to have a great day. Thanks.
bwtr
bwtr posted Sun, 07 November 2004 at 6:44 PM
Terrain Tute Zip of 2.17mb seems to download ok but will not accept UnZip instruction. Many tries! Have been sidetracked and hope to do lots of experimentation today
bwtr
Nicholas86 posted Sun, 07 November 2004 at 7:14 PM
bwtr- Its possible you need a different unzip utility. What are you using? I generally use WinRAR myself, but its possible some things from WinZIP may not unzip with it. Just a suggestion. Brian
bwtr posted Sun, 07 November 2004 at 8:03 PM
Brian. No problems with anything from Juliens or any other bwtr sites before from a Full download so doubt is WinZip.bwtr
bwtr
julien_chaplier posted Sun, 07 November 2004 at 8:54 PM
A piece of the file was missing, I uploaded it again, this time it's complete.
bwtr posted Sun, 07 November 2004 at 10:05 PM
bwtr
julien_chaplier posted Sun, 07 November 2004 at 10:39 PM
Send me the file at julien_chaplier@yahoo.com, I'll check it. I need to know where the problem is coming from. And I had trouble downloading the new file from the website, the wrong one was in the internet cache and I needed to erased it to get the new one. Plus it's a C4 file, I'm not sure you can open it with C3.
bwtr posted Mon, 08 November 2004 at 6:13 PM
bwtr
julien_chaplier posted Mon, 08 November 2004 at 6:18 PM
Nice image, glad to see that the fix for C3 works.
