Subject: Any info out htere on how to make characters MIMIC ready?
lynnJonathan opened this issue on Dec 05, 2000 ยท 4 posts
lynnJonathan posted Tue, 05 December 2000 at 10:34 AM
Are there any tutarials or info on the facial morphs you need to make characters MIMIC ready. Don't they have to have special kinds of facial morphs, or do they just need to have the standerd Poser male and female morphs?
polartech posted Tue, 05 December 2000 at 11:10 AM
Just the standard morphs work fine. You can always tweak any others on the character in the Animation Palette after applying the pose if you want.
MikeJ posted Tue, 05 December 2000 at 9:13 PM
I've had troubles when using a .wav that has been altered, as far as speed and pitch are concerned, even when using a perfectly punctuated text file. Is this what you're taliking about? I've especially had this problem with Victoria. Mike
TRAVISB posted Wed, 06 December 2000 at 11:02 AM
I HAVE MIMIC AND IT SEEMS TO WORK BEST WITH PO4 AND SOME 3 MODELS BUT IT ONLY SEEMS TO WORK WELL AT 24FPS I DONT THINK IT WORKS WITH VICT AND MIKE CAUSE THE POLY COUNT ALSO LABTECH MAKES A MIC DESIGNED FOR VOICE RECONIZATION THIS IMPROVED THE PERFORMANCE IMMENSLEY
