Subject: Looking for ram-sheep horns
winter200 opened this issue on Nov 05, 2004 · 6 posts
winter200 posted Fri, 05 November 2004 at 10:03 AM
The ones that curl. Found a tut all over the place to make them in bryce. Got bryce but don't know how to use it. I need something that can be used in poser or imported. Thought I'ld seen some freebees before - cann't find now when I want them though. Does anyone know where they are? Thanks
wheatpenny posted Fri, 05 November 2004 at 2:39 PM Site Admin
Like this? Took me a couple minutes to make it in Rhino.If this is what you need then I can easily make a pair, even put them in Poser format for you as smart-props. Any particular figure you want it smart-propped for?
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
winter200 posted Fri, 05 November 2004 at 4:33 PM
perfect! They just have to fit on the upper sides of a female dolls head. I'm makeing a scene using the tiny lina but propping them to vicky2 or 3 would be fine. Even p4 or p5 woman. I can ajust the size down. Look good! Thank you very much!
wheatpenny posted Fri, 05 November 2004 at 5:36 PM Site Admin
Attached Link: http://www.renderosity.com/artistdownload.ez?fileid=15186&key=442093
Here you go...
Jeff
Hablo español
Ich spreche Deutsch
Je parle français
winter200 posted Fri, 05 November 2004 at 5:41 PM
Got them. Thank you again Martain manhunter.
Cybermonk posted Sat, 06 November 2004 at 8:12 AM
Attached Link: http://www.armanisoft.ch/webdesign/FrmDownloads.html
Spiralizer is a pretty neet program you might want to check out.
____________________________________________________
"The true sign of intelligence is not knowledge but imagination".
Albert Einstein
