narvik opened this issue on Dec 06, 2000 ยท 5 posts
narvik posted Wed, 06 December 2000 at 5:11 PM
Hey all. Okay the modifications with the magnets worked very well. Thanks JeffH for the help. Now for the eyebrows; how can I easily change the size of an existing Poser4 model's eyebrows. Is there some sort of texture that can be modified? Best, Marius
JeffH posted Wed, 06 December 2000 at 8:45 PM
In what way do you want to change the size? P4 Male or Female?
narvik posted Wed, 06 December 2000 at 8:59 PM
Thanks for the reply, JeffH. It's Poser 4 Male; and I want to make them fuller/thicker; although I must say also that in the meantime I have purchased 'Micheal', and it might be easier with 'him' I'm still playing araound with it right now. Marius
Jaager posted Wed, 06 December 2000 at 10:04 PM
With Michael, it is pretty straight forward. Morphs are not needed. One way to do it: 1.Just make the brow texture on the head the same as the skin surrounding it. 2.Either make a fur texture or jusr Poser color for the Upperbrow. 3.Control the size of the brow as well as the density by the use of a transMap: white shows, black does not. Trans slides set Min/max = 100% highlights = 0,0,0 (black) 4.Set the upperbrows so that they are just barely touching the head. If you have a paint program which supports layers, you can mix and match border shape, fur density, fur direction and get several versions with not so much work.
JeffH posted Thu, 07 December 2000 at 5:58 AM
Attached Link: http://www.renderosity.com/funstuff.ez?Search=Yes
There are several full brow texture maps for the Michael figure in the FreeStuff. Do a search for "Mike" and "Michael" separately to get them all. http://www.renderosity.com/funstuff.ez?Search=Yes -JH.
