Subject: Is there a fix for V3 ugly bent legs?
Jovial opened this issue on Nov 10, 2004 ยท 8 posts
Jovial posted Wed, 10 November 2004 at 2:12 PM
Hi, I tried every dial that I could find (in a morphed up V3) and nothing really got rid of the ugly overly-flat bit on the top of V3 thighs. Is this a known and accepted problem for V3 or is there a solution to it? The minimum flatness was achieved using more buttock bend and less thigh bend, but I still think there is room for improvment with the top of the leg being more rounded. See green circled areas on the image. Thanks for any help or suggestions you can give. Regards from, Jovial.
PabloS posted Wed, 10 November 2004 at 2:21 PM
Maveris has a an adjustment pose that should fix this at RDNA's freestuff. "INJ-REM AdjButtock V3"
Message edited on: 11/10/2004 14:23
FlyByNight posted Wed, 10 November 2004 at 2:25 PM
Attached Link: http://www.runtimedna.com/
Maveris has made three INJ/REM utilities to help with this buttocks flattening problem, also for the shoulder and eye problems of V3 at RDNA. Check in Free RDNA.
FlyByNight
FlyByNight posted Wed, 10 November 2004 at 2:26 PM
Heheh, looks like PabloS and I posted at the same time.
FlyByNight
Jovial posted Wed, 10 November 2004 at 2:33 PM
Doh! Sorry! Thank you for the advice. I had actually downloaded the mentioned items but I did not know what they did (because the text on the download page is a little uninformative) and I have not tried them out yet. Time to squeeze some more into my runtime. Thanks again from, Jovial.
Maveris posted Wed, 10 November 2004 at 4:24 PM
Attached Link: http://www.runtimedna.com/messages.ez?forum_id=4&Form.ShowMessage=101463
Hi Jovial, Sorry for delay... The package is a little INJ-REM pose file that add two dials to the V3's BODY actor to adjust the buttocks. Hope help you, Mav :)
odeathoflife posted Wed, 10 November 2004 at 8:11 PM
will these work on the rr version?
♠Ω Poser eZine Ω♠
♠Ω Poser Free Stuff Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
Maveris posted Thu, 11 November 2004 at 1:36 PM
Hi odeathoflife, Sorry, but the INJ-REM poses are deltas for the standard V3 figure... So don't work if the obj geometry if different. Mav :)
