frost opened this issue on Nov 14, 2004 ยท 8 posts
frost posted Sun, 14 November 2004 at 9:16 PM
Sorry if this has been asked before, I did attempt to do a search. Ok so I've been playing with Vicky/Mike 3 for some time now, but is there a way to minimize the number of morphs. When you buy character paks is there a way to just make the multiple head morphs into one morph. Sorry daz if this goes against your copywright, I am not trying to redistribute, I just want to make one file/dial for the face I make. I either lose the orginal face when either adding expressions or from system crash when too many morphs are loaded. Thanks for any help anyone can provide me.
xoconostle posted Sun, 14 November 2004 at 9:32 PM
You can use Injection Pose Builder from DAZ to save INJ and REM poses for your face morphs. The app makes it possible to limit the number of morphs injected to the ones that are used in the pose. IPB is what you want to do what you want to do. :-)
frost posted Sun, 14 November 2004 at 9:48 PM
Are you able to combine the morphs into one morph in IPB. I use dial cleaner and IPB clear out the extra dials that aren't being used. And if possible, can you describe exactly how to do this. Thanks again.
ockham posted Sun, 14 November 2004 at 10:02 PM
The simplest solution is just to get the
face as you want it, then hit
Object: Spawn Morph Target
on the main menu. This will add a
new dial to the Head.
Resave the figure under a new name,
and you'll then have one dial
to control the face you want.
Edit: be sure the Head is selected when
you hit Spawn Morph Target.
Message edited on: 11/14/2004 22:04
frost posted Sun, 14 November 2004 at 10:24 PM
thanks, that worked fine.
Lyrra posted Mon, 15 November 2004 at 4:59 AM
note: the combined morphs is STILL not distributeable also, you can use MorphManager to combine morphs as well.
ENGELKEN posted Mon, 15 November 2004 at 6:19 AM
Hi, Lyrra. Your tunic tex's are awesome. Thank you, thank you.
As to the "not distributeable" thingee...
I find it hard to believe that all the V3 head/face morphs available in Free Stuff and Marketplace are only done with Magnets or in other Modelling Programs. I suspect some of them are combinations of existing morphs and original tweaks combined as described above and then set up to inject in a different channel.
But I could be wrong.
TrekkieGrrrl posted Mon, 15 November 2004 at 6:47 AM
Most of the head/face morphs in free stuff are injection poses. And those ARE distributeable, as you need to have the morphpacks in order to use them. Some are also totally custom made, but most are dial settings, distributed as inj. poses. Those CAN be combined with totally homemade morphs too. And STILL be fully legit.
