Neyjour opened this issue on Nov 18, 2004 ยท 3 posts
Neyjour posted Thu, 18 November 2004 at 7:17 PM
Is there any way to make it work in ProPack? I tried both the P4 and P5 versions with no luck. It just ran me through a series of error messages. :( Any help would be great! Ney
"You don't know what we can see
Why don't you tell your dreams to me
Fantasy will set you free." - Steppenwolf
DominiqueB posted Fri, 19 November 2004 at 9:16 AM
After taking a quick look at the cr2, there are a few problems that you will have to manually edit,when you unzip the killercube.zip the claw.obj is in a folder called Geometries this is incorrect according to the cr2. 1.Create a folder called arcanestudios as follows: RuntimeGeometriesarcanestudios put the claw.obj in this folder. Poser will now be able to locate the obj. This is for both P4 and P5 versions of the cr2 2. Open up the cr2 file in wordpad, and change: version { number 5 to number 4.01 so Poser 4 can read it. Save the file At first glance this should be all you need to do. I can't test it here, Poser is unavailable to me at this time. Let us know if this works.
Dominique Digital Cats Media
mapps posted Fri, 19 November 2004 at 9:58 PM
If you download the "merchant utility" here in the free section it will switch the p5 info to p4 info for you :-) I use it to make my free items more compatible with p4 and pro users as I only have Poser 5. It works very well, I don't get any complaints that 4 users are haveing problems with the files. :-) If you open the cr2 files (or pp2 files as is the case with most of my posts) after uing the utility the information is organized better for editing too.
