peevee opened this issue on Nov 19, 2004 ยท 4 posts
peevee posted Fri, 19 November 2004 at 11:34 AM
How do I import poser made scenes into mojoworld? Or is it just impossible ? Thanks Me
pakled posted Fri, 19 November 2004 at 12:37 PM
uh...uh..I don't know..I've seen a very few Mojoworld pics with objects in them. A lot of it looks like Postwork..I'd check the Mojo forum, they're more likely to have an answer..
That being said, you can make an image in Mojoworld, then File|Import|Background picture into Poser, and do it that way..Dr. Geep has a good tutorial on that..a few posts down from here..
dan whiteside posted Fri, 19 November 2004 at 12:56 PM
Just export from Poser to .OBJ and in MJW click the icon that looks like an AC plug and select Load Mesh. In the file selector load the Poser .OBJ and after MJW loads the file (may take a while) an odd crosshair Icon will appear in the main window - click and hold down the mouse button and drag out the object(s) to whatever size you want. You'll probably also get asked to locate the Poser image textures, if any. This is how to do it in MJW2 - don't know about the new MJW3. Also, if you're using Poser 5 you'll not get any procedural textures cause P5 only exports image textures. HTH; Dan
Erlik posted Fri, 19 November 2004 at 4:32 PM
Go to the pandromeda.com site and do a search for Calyxa's tutorials. She's got one on importing the Poser figures.
-- erlik
