hogwarden opened this issue on Nov 22, 2004 ยท 9 posts
hogwarden posted Mon, 22 November 2004 at 11:02 AM
Attached Link: QuickMAT is an astonishing $14,95!
Hogsoft QuickMAT enables you to save MAT poses **directly from the Poser scene**. With QuickMAT, gone are the days of laboriously browsing for files and manually converting thumbnails. Instead, QuickMAT will make the MAT you want, together with rsr and png thumbnails, in a couple of clicksThanks to inovative new technologies such as P4PyE (Poser 4 Python Emulation), QuickMAT works with Poser 4, 5 and Pro Pack
This is by far the simplest and quickest way to make MAT poses ever!
With QuickMAT you can instantly make all conceivable types of material MAT file
QuickMAT has Thumb-o-Matic integrated into it. ToM makes fully rendered png and/or rsr thumbnails straight from the Poser Document Window for your MAT files
You can chose to use the Poser-generated thumbnails if you prefer (PP and P5 only)
The Python scripts for Pro Pack and Poser 5 are automatically installed into the Poser Python Pallette
You can choose the folder to save in a new PBooost-aware browser system (if PBooost is installed)
Set-and-forget preferences and advanced options
Automatically chooses the Poser file type for the MAT (pose, camera, face) depending on the save folder (overrideable)
Can save as compressed or uncompressed MAT files
Customizeable comment line placed into the MAT files
The installer has the Hogsoft Utility Hub included! .
QuickMAT is incredibly easy to use... the Mat creation workflow is very different to anything previously available!
