Mun opened this issue on Nov 30, 2004 ยท 20 posts
Mun posted Tue, 30 November 2004 at 1:29 AM
Attached Link: http://philipfong.tripod.com/id10.html
Can anyone tell me if there is a solution to alpha masking or transperancy mapped to cut away portion of a model? The edges appear to have a glow arround the croped section, I have tried both transperancy, oppacity, glow but nothing works. how do you do this kind of masking anyway? Thanks. PhilipTOXE posted Tue, 30 November 2004 at 2:16 AM
TOXE posted Tue, 30 November 2004 at 2:25 AM
TOXE posted Tue, 30 November 2004 at 2:51 AM
falconperigot posted Tue, 30 November 2004 at 3:06 AM
That is so sad! :-(
TOXE posted Tue, 30 November 2004 at 3:23 AM
rendererer posted Tue, 30 November 2004 at 5:17 AM
This would be a fun contest - who can slice up this guy in the meanest and funniest way. :-D
Mun posted Tue, 30 November 2004 at 5:28 AM
Attached Link: http://www.3dcommune.com/3d/galview.mv?Carrara_RDS+amZbNFtFw+1101805336+&v_index=5&nd=1101820314
Yeaks! wrong link above, sorry here it is at 3d commune. I forgot that you can post image here. Thanks for the examples, I am still using C3 and the result is not like that, it seems like the croped area is not complete leaving glow edges. I'll try to convert the mask to greyscale.falconperigot posted Tue, 30 November 2004 at 10:15 AM
Well, I reckon TOXE would win any MEANESS contest hands down (or is that hands up?). I just WEPT when I saw the holes in that poor guy. I shall join SCULPT immediately (that's the society to Stop Cruelty and Unpleasantness to Little Polygon Thingies) ;-)
TOXE posted Tue, 30 November 2004 at 11:18 AM
Pete_Exxtreme posted Tue, 30 November 2004 at 1:20 PM
LOL !!!!!! Excellent !
falconperigot posted Tue, 30 November 2004 at 1:48 PM
Mun posted Tue, 30 November 2004 at 8:35 PM
falconperigot posted Wed, 01 December 2004 at 2:42 AM
Attached Link: Transparency shader tree
Mun, check out the method in this thread. If you still can't get it to work post a screen shot of your shader tree. It is perfectly possible to do what you want.Mun posted Wed, 01 December 2004 at 7:32 AM
Hah! I got it! Its the blender, why an extra image map to do that, I was planing to use this technique on my new models but seems won't that increase file size or render time?
falconperigot posted Wed, 01 December 2004 at 12:48 PM
You can do it with one map, in the blender, with values of 0 & 100 in the transparency channels of the two sources. The number of maps you have will only increase file size if you save them internally. And it's using transparency which will increase the render time; using texture maps - as opposed to procedural shaders - will reduce render time.
Mun posted Thu, 02 December 2004 at 12:12 AM
falconperigot posted Thu, 02 December 2004 at 1:23 AM
Looks good!
TOXE posted Thu, 02 December 2004 at 1:54 AM
I agree, really nice! You have modeled it with carrara?
Mun posted Thu, 02 December 2004 at 5:50 AM
It was from Hash and intended for OBJ export, it was edited in C3 to increase geometrical detail, C3 is able to edit while preserving the UV mesh. Apart from that I also do vector style and other renderings for models from Zbrush. Thanks for the help guys.
